Problem inserting PDF file printout in OneNote?
2013-01-16T13:32:50+00:00
I need to insert a PDF file printout into OneNote, but when I try I get the following error message:
The file you have selected cannot be inserted as a Printout. There may be a problem with the file, or you may not have the right program installed. You must first install a program that can open and print this file type, and then try again.
I've read through some of the other topics in the forums discussing this same problem, but I have no idea how to fix it. If someone could a) figure out what the problem is, and b) walk me though the steps of fixing it.. it would be greatly appreciated!!
I have no problems inserting the other sort of file I've tried inserting as a printout: powerpoint.
2014-06-08T12:32:00+00:00
I had the same problem from earlier this year (2014) and just upgraded to OFFICE365 and now it all works fine. Must have been a glitch with the 2010 version as it was working for ages and then stopped working earlier this year.
42 additional answers
    2016-10-11T08:39:18+00:00
    I had the problem which I am assuming is exactly the same as you have whereby when I try and insert a PDF it just hangs for ever. I tried reinstalling one note and running the repair with no success and on a whim I then tried to install Onetastic which I had  previously. The problems immediately went away. Hope this helps somebody.
    Andy
    2016-10-26T02:20:42+00:00
    office 365 has the same problem and even worse influents the os as well
    and have effect on edge too
    edge crashes and stops working
    2016-11-01T19:21:01+00:00
    Hi Bennie,
    To verify, you're still getting the "The file you have selected cannot be inserted as a Printout. There may be a problem with the file, or you may not have the right program installed. You must first install a program that can open and print this file type, and then try again." error even after upgrading to Office 365. Is that right? Are you using an Office 365 Personal, Home, or Business edition? Are you using Adobe Acrobat, Abode Reader, etc.? For the Edge concern, apart from the troubleshooting steps that you've tried, can you also consider doing a clean boot? See: How to perform a clean boot in Windows for instructions.
    Let us know how it goes.
    2017-03-29T15:10:01+00:00
    Hi Omer
    Thanks for your help this sounds really promising.
    I am not an computer ace, could you maybe help me solve this problem step by step.
    I get to the regeditor and to the folder, but I am not sure what I have to change there.
    I'd appreciate your help!
    Thanks a lot already,
    Bea
