Problem inserting PDF file printout in OneNote?
2013-01-16T13:32:50+00:00
I need to insert a PDF file printout into OneNote, but when I try I get the following error message:
The file you have selected cannot be inserted as a Printout. There may be a problem with the file, or you may not have the right program installed. You must first install a program that can open and print this file type, and then try again.
I've read through some of the other topics in the forums discussing this same problem, but I have no idea how to fix it. If someone could a) figure out what the problem is, and b) walk me though the steps of fixing it.. it would be greatly appreciated!!
I have no problems inserting the other sort of file I've tried inserting as a printout: powerpoint.
2014-06-08T12:32:00+00:00
I had the same problem from earlier this year (2014) and just upgraded to OFFICE365 and now it all works fine. Must have been a glitch with the 2010 version as it was working for ages and then stopped working earlier this year.
42 additional answers
    2013-01-18T13:02:12+00:00
    I reinstalled Acrobat Reader and now I have the print option when right clicking a document. However, OneNote still doesnt insert the file as a printout. Same error message.
    2013-01-26T13:53:53+00:00
    I have this issue too. Others (that I know) and all around the web have this issue, for a long time (several months it seems).
    The error is bogus, as it clearly is capable of putting documents inside itself, but only when printed "to onenote".
    I have read that this is a licensing issue between Adobe/Microsoft (although I don't understand why - pdf format is widely available in non-adobe products), and it makes no difference what version of pdf reader you use it seems. I have tried several, including nitro, primo, cutepdf, and adobe, all of which fail.
    This is a shortcoming of the Office software it seems, with no (known) solution, not a user configuration/installation error.
    2013-01-28T18:06:34+00:00
    I understand the frustration, but making random claims won't help anyone. There isn't some licensing issue between Adobe/Microsoft that would prevent you from inserting printouts into OneNote.
    Here is how this works and why it fails for some people:
    OneNote doesn't know how to print any document. It relies on applications registering themselves for printing file extensions. This registration is in the registry. OneNote checks the following keys:
    Assuming the extension of the file you are trying to insert is .pdf. We first check:
    HKEY_CLASSES_ROOT.pdf
    My computer has this value: (Default)=AcroExch.Document
    This gives us the programmatic identifier of the file type, then we check for the current version of the identifier:
    HKEY_CLASSES_ROOT\AcroExch.Document\CurVer
    My computer has this value: (Default)=AcroExch.Document.7
    Then we use this identifier to check if an application is registered to print. This can be either one of the following:
    HKEY_CLASSES_ROOT\AcroExch.Document.7\shell\Printto\command
    My computer has this value: (Default)="C:\Program Files (x86)\Adobe\Reader 10.0\Reader\AcroRd32.exe" /p /h "%1"
    HKEY_CLASSES_ROOT\AcroExch.Document.7\shell\Print\command
    My computer has this value: (Default)="C:\Program Files (x86)\Adobe\Reader 10.0\Reader\AcroRd32.exe" /t "%1" "%2" "%3" "%4"
    Then OneNote executes the command in these keys. Now we have no idea what application this launches and what it does, we assume it will print the passed in file name back to OneNote. If we cannot find one of the registry keys above, or executing the command in the key fails (e.g. AcroRd32.exe is not found or is corrupt etc.) we will display the error mentioned here.
    The error is not bogus, it says: "The file you have selected cannot be inserted as a Printout. There may be a problem with the file, or you may not have the right program installed. You must first install a program that can open and print this file type, and then try again."
    This isn't about putting the document inside OneNote, it is about the printing part. That is why when you print to OneNote, everything is fine. OneNote doesn't know how to do the "printing" part if the registration in the registry is missing or incorrect.
    There can be of course some subtle bug either in OneNote or the application that handles the file type, that causes this to fail even though you have an application that handles the file type installed. Note that if the application is only registering itself for "open" and is not registering for "print", then it doesn't help.
    The registration also surfaces itself when you right click on a printable document in windows explorer as a menu item named "Print". That is why I refer people to check that when they hit this problem.
    2013-04-12T07:04:45+00:00
    Is it intended that the built in reader for Windows 8 does not create the appropriate entries in the registry for the print context for PDFs?  If I have a fresh Windows 8 install using Reader to read PDFs and OneNote 2013, I can't import them using Insert File Printout, only with printing from within the reader app itself.
