Problem inserting PDF file printout in OneNote?
2013-01-16T13:32:50+00:00
I need to insert a PDF file printout into OneNote, but when I try I get the following error message:
The file you have selected cannot be inserted as a Printout. There may be a problem with the file, or you may not have the right program installed. You must first install a program that can open and print this file type, and then try again.
I've read through some of the other topics in the forums discussing this same problem, but I have no idea how to fix it. If someone could a) figure out what the problem is, and b) walk me though the steps of fixing it.. it would be greatly appreciated!!
I have no problems inserting the other sort of file I've tried inserting as a printout: powerpoint.
2014-06-08T12:32:00+00:00
I had the same problem from earlier this year (2014) and just upgraded to OFFICE365 and now it all works fine. Must have been a glitch with the 2010 version as it was working for ages and then stopped working earlier this year.
42 additional answers
    2017-10-05T19:04:42+00:00
    Hi.  I have one note 2016. PDF associated with  A.A.R. Still doesn't work .
    2017-10-18T23:25:35+00:00
    But I can right click on a pdf file and click print and it will do it just fine.  It only doesn't work when trying to insert a printout in OneNote.  I have Office 2013 with Windows 7.
    2017-10-19T21:46:22+00:00
    Finally, quite a few headaches later, Here is my new try : Windows 10 + One note 2013, Microsoft office Pro plus 2013: I have got my easy and happyprint in One note.
    2017-10-28T13:21:16+00:00
    I cant print out from my computer.. Please help
