why the fonts in word 2013 are blurry?
2013-01-31T05:32:47+00:00
rendering the fonts in word 2013 is horrible!
Will Microsoft change it?
This is a similar problem like with Internet Explorer 9 & 10.
What is going on?
IE8 works good, Office 2010 also...
Then?
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2013-02-07T22:33:51+00:00
Check under File>Options>Advanced>Display and check the box for "Use subpixel positioning to smooth fonts on screen" and also try changing the setting for "Disable hardware graphics acceleration"
117 additional answers
    2013-08-09T03:06:23+00:00
    Go to File>Options>Advanced>Display>Check the Box for Disable Hardware Graphics Acceleration. I had the same problem.
    2013-08-09T21:08:58+00:00
    If you are using windows 8, do a search for ClearType Text and enable "Turn on Clear Type". That fix my problem for me.
    2013-09-16T12:03:42+00:00
    This is don't help me
    2013-09-16T13:43:29+00:00
    In that case rather than tacking on to a question that has been marked ANSWERED  you should start a new one.
    The more details you provide up front, the sooner you stand a chance of getting a reply that works.
    Describe your problem in detail.
    In detail, describe the steps you have taken to try and fix the problem. You can include a link back to this question if you wish.
