why the fonts in word 2013 are blurry?
2013-01-31T05:32:47+00:00
rendering the fonts in word 2013 is horrible!
Will Microsoft change it?
This is a similar problem like with Internet Explorer 9 & 10.
What is going on?
IE8 works good, Office 2010 also...
Then?
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2013-02-07T22:33:51+00:00
Check under File>Options>Advanced>Display and check the box for "Use subpixel positioning to smooth fonts on screen" and also try changing the setting for "Disable hardware graphics acceleration"
117 additional answers
    2017-05-12T06:32:53+00:00
    Solved my problem. Thanks!
