why the fonts in word 2013 are blurry?
2013-01-31T05:32:47+00:00
rendering the fonts in word 2013 is horrible!
Will Microsoft change it?
This is a similar problem like with Internet Explorer 9 & 10.
What is going on?
IE8 works good, Office 2010 also...
Then?
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2013-02-07T22:33:51+00:00
Check under File>Options>Advanced>Display and check the box for "Use subpixel positioning to smooth fonts on screen" and also try changing the setting for "Disable hardware graphics acceleration"
117 additional answers
    2013-02-08T18:49:31+00:00
    OUTSTANDING!!!! Doug, Your The Man!!! BY GOD IT WORKS NOW. Can you tell I'm Happy? I can get out of the Doghouse now with my wife. As you suggested: checked the Display: the "Use subpixel positioning..." was already checked on (presuming it is the Default). Then I found the "Disable hardware graphics acceleration" box Unchecked. I checked the box and exited. Immediately the document on the screen (and Word menus) were clear. I next went to the Font menu box and scrolled up and down the listed Fonts. Instant change for the selected area (I had selected the whole doc) per the highlighted Fonts. Really Impressive to see such changes occur real-time. Next, loaded Excel and a file with text, numbers and graphics. Clear as a bell. I am going to send the Microsoft tech rep who `helped' me last and tell him YOU found the answer to their ****-a-Mamie new feature. Three Cheers for Doug! Hip-Hip-Hooray, Hip-Hip-Hooray,Hip-Hip-Hooray!
    2013-02-08T20:33:27+00:00
    Thank you so much for reposting this information.  It does help me with my buying decisions.
    2013-02-09T21:43:48+00:00
    was not working for me ... tried any constellation, but still blurry ...
    2013-02-14T22:19:33+00:00
    Go to File -> Options -> Advanced
    Under Display, check Disable hardware graphics acceleration
    That's all you need to do and you don't need to restart anything.
