why the fonts in word 2013 are blurry?
2013-01-31T05:32:47+00:00
rendering the fonts in word 2013 is horrible!
Will Microsoft change it?
This is a similar problem like with Internet Explorer 9 & 10.
What is going on?
IE8 works good, Office 2010 also...
Then?
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2013-02-07T22:33:51+00:00
Check under File>Options>Advanced>Display and check the box for "Use subpixel positioning to smooth fonts on screen" and also try changing the setting for "Disable hardware graphics acceleration"
117 additional answers
  1. Deleted
    2016-12-20T13:10:58+00:00
    Had similar issue with Office 2013 on a Surfacebook running Windows 10. The text looked terrible in Outlook on the external monitor. The laptop's internal screen looked fine.
    I went into Control Panel > Display > Set a custom scaling level. Changed from 200% to 100%. Signed in and out and fonts are clear in Outlook.
    2017-01-09T19:05:42+00:00
    This did not help at all. I am unable to work.
    2017-01-09T20:57:06+00:00
    What is going on?
    Then?
    You can also try https://www.openoffice.org/?redirect=soft
    This is freeware.
    Grt Jorg
