A family of Microsoft word processing software products for creating web, email, and print documents.
There is a trick to enable the "classic" style for text boundaries in Word 2013 and 2016: You can set compatibility to Word 2010.
Here's how to do it: Make sure the document that you want to change is the active document in Word. Press Alt+F11 to display the Visual Basic Editor. Press Ctrl+G to activate the Immediate window. Type
ActiveDocument.SetCompatibilityMode wdWord2010
and press Enter. Close the Visual Basic Editor and click File | Options. In the Advanced category, scroll down to the bottom where you will now see the list of layout/compatibility options. For "Lay out this document as if created in," select Word 2010. Click OK to close the dialog box and then save the document.
Everything, including text boundaries, will work the way it did in Word 2010.
