Does visio 2013 have a WBS Modeler add-in?
2013-04-30T18:20:25+00:00
I have Visio 2013 Pro and Project 2010 Pro and am attempting to create a WBS diagram. I have found results for a Visio 2010 WBS modeler add-in but can not find anything for Visio 2013.
As such how would one create a WBS diagram in Visio 2013?
Microsoft 365 and Office | Access | For home | Windows
2013-11-22T12:42:39+00:00
Villiam, Use the 32 bit WBS modeler to run on your machine. I faced the same issue using the 64 bit install, but the 32 bit version works well on 64 bit Visio. Let me know how it goes.
44 additional answers
    2015-08-05T19:27:01+00:00
    I can't find the WBS X32 anywhere. Can someone please send me the link for it?
    2015-08-12T16:36:15+00:00
    Dear Mona,
    Is there a plan to make Visio 2013 X86 compatible with WBS Modeler?
    Uncle Tony
    2015-08-13T12:15:00+00:00
    Hi Sanjay,
    I've just installed the WBS Modeler 2010 for Visio 2013 Pro. But can seem to get it to work. I also cant find it in the home pages of Visio. Do you have a manual with screen shot about how to set it up. I might be putting it in the wrong place.
    Gerard
    2015-08-13T12:26:05+00:00
    It doesn't work, Gerard
