Does visio 2013 have a WBS Modeler add-in?
2013-04-30T18:20:25+00:00
I have Visio 2013 Pro and Project 2010 Pro and am attempting to create a WBS diagram. I have found results for a Visio 2010 WBS modeler add-in but can not find anything for Visio 2013.
As such how would one create a WBS diagram in Visio 2013?
Microsoft 365 and Office | Access | For home | Windows
2013-11-22T12:42:39+00:00
Villiam, Use the 32 bit WBS modeler to run on your machine. I faced the same issue using the 64 bit install, but the 32 bit version works well on 64 bit Visio. Let me know how it goes.
44 additional answers
    2014-01-28T22:08:51+00:00
    I have Visio 2013 and downloaded the x86 WBS modeler addin for visio 2010 and installed it.  When I start Visio, there's this error message from WBS Modeler: "WBS Modeler requires Microsoft Office Visio 2010".
    Did you get this - Villiam / Amardeep?
    Thanks!
    2014-06-05T19:32:20+00:00
    I installed this today and imported a Project 2013 plan. I'm on a Win64 7 and with 32bit Project/Visio
    2014-09-05T18:51:46+00:00
    Hi Amardeep Dabass,
    I have tried to install 32 bit WBS modeler for 64 bit Visio 2013 Pro as you adviced. I'm on Win64 8.
    However when I tried to use function "Add child elements" it does not work,  new element is not appeared and even error message is not appeared.
    Could you please advise what could an issue here?
    Many thanks!
    Eugeny
    2014-09-06T17:42:23+00:00
    Eugeny,
    If your using 64 bit Visio you have to use 64 bit WBS modeler.
    Select this, Visio Add-In for WBS Modeler (X64).msi, from here,
    http://www.microsoft.com/en-us/download/details.aspx?id=26229
    Notice the "X64"
    Residentx
