Does visio 2013 have a WBS Modeler add-in?
2013-04-30T18:20:25+00:00
I have Visio 2013 Pro and Project 2010 Pro and am attempting to create a WBS diagram. I have found results for a Visio 2010 WBS modeler add-in but can not find anything for Visio 2013.
As such how would one create a WBS diagram in Visio 2013?
Microsoft 365 and Office | Access | For home | Windows
2013-11-22T12:42:39+00:00
Villiam, Use the 32 bit WBS modeler to run on your machine. I faced the same issue using the 64 bit install, but the 32 bit version works well on 64 bit Visio. Let me know how it goes.
44 additional answers
    2016-12-09T19:21:19+00:00
    Not working for me still :( - I can see the WBS add in but can't import project data
    2017-04-18T21:06:18+00:00
    Sure, you can install the template but it doesn't really work.  The add-on ribbon does not appear when opening the template in Visio 2013, so you can't import data from MS Project.
    2017-05-04T08:40:16+00:00
    Now is True. It export fine but can't import. Try 32 bit WBS modeler to run on 64 bit Visio:)
    2017-07-26T18:52:16+00:00
    I have the same problem, I did the suggested but still the same. If possible I would advise me how to solve it.
    Greetings and thanks
