Excel "=SUM" formula does not add up numbers correctly
2013-04-02T16:39:01+00:00
I have an Excel formula issue in the formula not resulting in the correct sum, but it is not a rounding error; rather it is off by an entire cell amount. As an example, I was adding eight cells with the value of $3,001.53 which should have resulted in a total of $24,012.24, but instead I got $21,010.71 (off by one cell value). I triple-checked to make sure that the formula included all cell addresses I was trying to add, which it did. I tried deleting the formula and doing it over again, saving the spread sheet as different versions of Excel, putting the formula in a different cell location, all to no avail. There were other similar errors in the spread sheet. FYI, I am not adding concecutive cells, rather, selecting certain cells using Ctrl, left click.
I'm using Excel 2010 Version 14.1.6129.5000 (32-bit).
Please advise.
    2013-04-02T17:03:00+00:00
    Hi, are you sure you are including  the cell with 3K could you post the formula
    2013-04-02T17:03:39+00:00
    Please advise.
    Perhaps one of the cells is Text?
    Re-format all to General then F2>Enter on each.
    Gord
    2013-04-02T18:55:58+00:00
    I agree with Gord - the other issue could be that your calculation mode is set to manual and the number was added after you entered the formula...
    2013-04-02T23:52:52+00:00
    Hi.  When you select the 8 cells, take a look at the lower right corner of the status bar line.
    What does the 'Count and 'Sum say?
    (I just turned on 'Numerical Count' with Excel 2013.  I honestly don't remember if this was an option in Excel 2010.  I've had Excel 2013 now for only a week  :>~   )
    2015-06-16T08:54:09+00:00
    I've got the same problem using Microsoft Excel 2013.
    I've got a sum(L6:L35) giving me a sum of 84.5, yet, when I select them, the sum at the lower right corner of the status bar gives me 80 and when I add them up manually they add up to 80 as well!
    When I do a sumif, it also thinks the total there is 4.5 more then there really is!
