Arrow keys don't work in slide view mode in powerpoint
2013-02-24T03:42:39+00:00
My powerpoint used to work fine but recently I am unable to advance or move my slides backwards in the Slide view mode with arrow keys, space bar and return.  Nothing seems to work.  I cannot even exit the presentation with the ESC key.  I need to use the cursor to exit presentation.  Because of this situation, I cannot use the remote control to advance my slides.  PLS HELP!!!
2017-06-01T06:50:19+00:00
I have fixed the problem on my side following these steps:
  • Open the "Slide show" tab in the ribbon
  • Click on "Set Up Slide Show"
  • Make sure that following options are selected "Show type" = presented by the speaker (full screen) and "Advance slides" = manually
59 additional answers
    2013-02-26T10:48:34+00:00
    How did you bring it back to 14.2.3?  Mine is currently 14.3.1.  Please advise.  Thanks.
    2013-02-26T14:16:41+00:00
    Delete the whole Office
    Install again
    Load the updates
    There are some updates you need to take before the others..
    My last one, like I said: 14.2.3
    Again: I don´t know, if the 14.3.0 would be ok, but I´m just too tired to try..
    Forget about the 14.3.1, even if it didn´t cause the problem, it didn´t solve it!
    Works perfectly!
    2013-02-26T14:45:00+00:00
    Ok thanks for elaborating.  Will try it out.
    2013-02-26T15:07:22+00:00
    I'm having the same issue. I actually posted it in a different thread before finding this one. Looks like I'll be uninstalling and reinstalling Office tonight after work.
