Arrow keys don't work in slide view mode in powerpoint
2013-02-24T03:42:39+00:00
My powerpoint used to work fine but recently I am unable to advance or move my slides backwards in the Slide view mode with arrow keys, space bar and return.  Nothing seems to work.  I cannot even exit the presentation with the ESC key.  I need to use the cursor to exit presentation.  Because of this situation, I cannot use the remote control to advance my slides.  PLS HELP!!!
2017-06-01T06:50:19+00:00
I have fixed the problem on my side following these steps:
  • Open the "Slide show" tab in the ribbon
  • Click on "Set Up Slide Show"
  • Make sure that following options are selected "Show type" = presented by the speaker (full screen) and "Advance slides" = manually
59 additional answers
  1. Bob Jones AKA CyberTaz MVP 437.7K Reputation points
    2017-05-12T14:25:10+00:00
    Your intent to be helpful is appreciated, but do you realize that this conversation has been dormant for 4 years & pertains to PowerPoint 2011? Not to mention that it's been hijacked so many times that it's almost impossible to tell which message you're responding to :-)
    2017-06-05T11:59:40+00:00
    I'm kinda amazed this thread is still alive!
    But yeah, I found over time to do what andysko said.
    It has worked well for me.
    Hopefully this thread helps others or it still wouldn't be active.
    2017-07-06T19:37:01+00:00
    Awesome, this worked. Thank a bunch.
