How do I recover an accidentally deleted, never-saved autorecovery file?
2012-06-22T22:34:15+00:00
When I opened another word document, it asked me whether I wished to keep the autorecovered file (which I'd forgotten about), and I accidentally said "no."  Realizing I still want it, I found the document in my recycle bin and clicked "restore," but now I can't find it anywhere.  Please help!
Suzanne S Barnhill 279.5K Reputation points MVP Volunteer Moderator
2012-06-22T23:21:59+00:00
On the File tab, select Recent. At the bottom, click Recover Unsaved Documents. If your document is not listed there, then you're out of luck.
2012-06-23T10:55:20+00:00
Do you remember the name of the file?
If yes, you may use the Windows search and check if you find the file in your computer.
Enable hidden files and folders using the link below before doing the search:
http://windows.microsoft.com/en-US/windows7/Show-hidden-files
For information related to Windows search you may refer to the link mentioned below:
http://windows.microsoft.com/en-us/windows7/products/features/windows-search
44 additional answers
    2017-11-26T09:52:05+00:00
    You need to go to
    C:\Users(User Name)\AppData\Roaming\Microsoft\Word
    (User Name)- Being your username/ account name on your machine/laptop/desktop. Good luck!
    2017-12-20T15:54:45+00:00
    There's no "Recent" option in my file tab.
  3. Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
    2017-12-20T20:00:40+00:00
    When this thread started in 2012, it was about Word 2010, which does have an option called Recent on the File tab.
    In Word 2013 or 2016, click File | Info | Manage Versions | Recover Unsaved Documents.
