A family of Microsoft word processing software products for creating web, email, and print documents.
On the File tab, select Recent. At the bottom, click Recover Unsaved Documents. If your document is not listed there, then you're out of luck.
When I opened another word document, it asked me whether I wished to keep the autorecovered file (which I'd forgotten about), and I accidentally said "no." Realizing I still want it, I found the document in my recycle bin and clicked "restore," but now I can't find it anywhere. Please help!
Do you remember the name of the file?
If yes, you may use the Windows search and check if you find the file in your computer.
Enable hidden files and folders using the link below before doing the search:
http://windows.microsoft.com/en-US/windows7/Show-hidden-files
For information related to Windows search you may refer to the link mentioned below:
http://windows.microsoft.com/en-us/windows7/products/features/windows-search
I tried searching for *.asd file through the system search option but it did found nothing. That's strange because tehere are *.asd files on C: drive (just not these i'm looking for), but they didn't pop
up in searching...
Oh, thanks. Now it has found five *.asd files, but none of them is the one i'm looking for :(
