How do I recover an accidentally deleted, never-saved autorecovery file?
2012-06-22T22:34:15+00:00
When I opened another word document, it asked me whether I wished to keep the autorecovered file (which I'd forgotten about), and I accidentally said "no."  Realizing I still want it, I found the document in my recycle bin and clicked "restore," but now I can't find it anywhere.  Please help!
Suzanne S Barnhill 279.5K Reputation points MVP Volunteer Moderator
2012-06-22T23:21:59+00:00
On the File tab, select Recent. At the bottom, click Recover Unsaved Documents. If your document is not listed there, then you're out of luck.
2012-06-23T10:55:20+00:00
Do you remember the name of the file?
If yes, you may use the Windows search and check if you find the file in your computer.
Enable hidden files and folders using the link below before doing the search:
http://windows.microsoft.com/en-US/windows7/Show-hidden-files
For information related to Windows search you may refer to the link mentioned below:
http://windows.microsoft.com/en-us/windows7/products/features/windows-search
44 additional answers
    2017-10-26T01:20:23+00:00
    This exact thing happened to me, and it wasn't restored to the "Recover Unsaved Documents" folder.
    I went back into the recycle bin, right clicked on an empty space, and clicked "Undo move."
    The file then came back to the recycle bin. Instead of clicking restore, I dragged and dropped the file onto the desktop, and was then able to open it.
    2017-11-23T22:20:56+00:00
    Does anyone know how to recover unsaved and deleted *.asd file on Windows 10, Word 2016? Can't find it in: "C:\Users\*****\AppData\Local\Microsoft\Office\UnsavedFiles", can't find it in: "C:\Users\*****\AppData\Roaming\Microsoft\Word" can't find it in the bin. Is there any chance to restore it?
  3. Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
    2017-11-24T07:05:22+00:00
    You can search your C: drive for *.asd files.
    If you find such a file, try opening it from within Word (via File | Open). If that fails, move the file into Word's folder for recovered files and then try again.
