Office 2013 Word Keeps Freezing (Not responding)
2013-04-02T16:00:21+00:00
I have just purchased Office 2013 and have used Word for a couple of minutes, but it repeatedly stops responding in specific scenarios.
It is far too buggy for me to migrate from my previous version of Office.
Situations in which it freezes:
  • Opening the options menu
  • On start up (when it claims that it is not the default program) - I fixed this one by making it the default program for everything
  • Closing the word document and choosing not to save
  • Scrolling through a very long document
Excel does not seem to have the same bugs, and I have successfully reached the options page on that program to turn off graphics acceleration.
The main reason I purchased Office 2013 was for Word and I would really like to have it functioning properly.
I am currently very disappointed and annoyed.
Other (possibly) relevant details
Platform: Windows 7
Other
Microsoft Office 2003
Microsoft 2010 Starter (pre-installed on laptop purchase)
Thanks for the help.
    2014-03-07T22:47:41+00:00
    I found a 'workaround' to the freezing issue with Word. Since doing this method the freezing has not re-appeared. Seems silly but it has worked so far:
    1. When done with the file, hit save a few times
    2. minimize the window to the toolbar and go do something else for a bit. I haven't tested to find out how long to wait, so a few minutes should be ok.
    1. Then expand the window again, hit save again and you can close without freezing. The last save may not be necessary but I don't want to explore further.
    I am sure this can be tightened up with further testing but I am a writer not a software debugger. Microsoft can send me a check for the debugging work anytime.
    2014-03-23T19:39:27+00:00
    Hello Deepa
    I am now having the same issue with MSWord freezing up constantly.
    It is only happening with MSWord.  It started a few days ago with an MS update.  This is the first time I have had this issue.  I am using MS Office 2013 Professional.  It's been installed (on my new laptop) since last summer/early fall 2013.
    As soon as I open a document, it freezes.  My only option is to close Word down. It's completely unusable :((
    I've followed the steps you have provided to others' here including going into Programs/Features: Change: Repair ... but it's still not working.
    Please help!
  3. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2014-03-23T22:05:34+00:00
    See the Article “Why can’t I start my Office 2013 application at:
    http://office.microsoft.com/en-us/support/why-cant-i-start-my-office-2013-application-HA104011864.aspx
    If that does not help, then you might remove all traces of the Office installation by running the fixit from the following article:
    http://support.microsoft.com/kb/2739501
    and then reinstall Office by logging into www.office.com/myaccountwith your registered email address and click Install Office.
    2014-04-07T18:32:39+00:00
    Problem is still active. No bug fixes yet from Microsoft. This problem seems to extend to the whole Office 2013 suite. If I leave any of the programs open for about a minute or two, it will freeze. I don't even have to be doing a single thing, just leaving it open allows the freeze. For me to be able to get any work done, I have to furiously type and press CTRL+S every sentence or two for fear or losing information in the freeze. I'm running:
    • Windows 7 Professional 64-bit SP1, up-to-date
    • 6 GB DDR3 RAM
    • 1 GB GDDR5 GPU -  Radeon HD 5800 Series
    • Core i7 CPU
    Like everyone else, I have tried all of the suggestions given. Maybe it is some sort of memory exception? I don't think Microsoft cares to release any patches for it because they're focusing on their Office 365 suite now.
    Until the problem is resolved, I would recommend using an open source alternative such as Open Office or Libre Office.
  5. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2014-04-07T22:19:53+00:00
    A lot of problems with Office 2013 are caused by third party (non-Microsoft) applications.  This is my (expanding) list of things to try when Office 2013\365 won’t start or crashes:
    For the error message Error: "Microsoft Office cannot verify the license for this product." See:
    http://support.microsoft.com/kb/2797062/en-us
    Refer to the following website for information on repairing Office 2013\365:
    http://office.microsoft.com/en-us/project-help/repair-or-remove-office-2010-HA010357402.aspx
    See Office 2013 install woes - http://office-watch.com/t/n.aspx?a=1834
    See the KnowledgeBase article “Office 2013 applications crash on launch at the splash screen” at:
    http://support.microsoft.com/kb/2813143
    Or see the KnowledgeBase article Error: “Something went wrong and we can't sign you in right now” when trying to install Office 2013 at:
    http://support.microsoft.com/kb/2811180/en-us/
    Try to run word in safe mode by typing winword/safe.
    If thatdoes not helpthen, in the search box type winword --> Word 2013 will be displayed --> right click on it --> Select Properties --> Go to the compatibility tab --> Check to see if there is a check mark next to compatibilty mode.
    If it is checked then uncheck it and then uncheck the option of Run as Administrator if its checked.
    Now run the word
    Also see my response in
    http://answers.microsoft.com/en-us/office/forum/office\_2013\_release-word/microsoft-word-2013-has-stopped-working/67b81016-849f-481a-bce5-bf04797ac03b
    Do you have Abbyy Finereader installed on the PC? A number of people have reported that removing it overcomes problems with 2013.  See:
    Office programs may crash with the FineReader add-in installed at:
    http://support.microsoft.com/kb/2755838
    Do you have “Fun Tools” add-in? A number of people have reported that removing it overcomes problems with 2013
    Do you have Toshiba Book Reader installed on the PC?  It has been reported that uninstalling that brings Office back to working status.
    Do you have the Acrobat PDFMaker add-in.  It has been reported that uninstalling that overcomes an issue with a message appearing that states "The document contains macros. Macro support for this application is disabled. Features requiring VBA are not available. Would you like to open this document as a read only?"
    Also see: http://answers.microsoft.com/en-us/office/forum/office\_2013\_release-word/microsoft-word-has-stopped-working-when-i-close/8375b5b6-4f7e-46ed-a02b-90152ecad287#LastReplyand
    http://answers.microsoft.com/en-us/office/forum/office\_home-word/word-and-excel-2013-crashing-on-windows-7/5389390c-e989-4c8e-8fe0-62673f1410ce?page=4#LastReply
    It appears that there may be some hardware incompatibilities as well.  If you have the NVIDIA driver NVWGF2UM.DLL, try renaming it as: NVWGF2UM.oldas was mentioned in:
    From the File tab, select Options and then click on Advanced and then in the Display section of the dialog, check the box for Disable hardware graphics acceleration
    For the error message "There was a problem sending the command to the program", use Windows Explorer to access the C:\Program Files\Microsoft Office\Office15 folder and right click on WINWORD.EXE then on Properties, go to the Compatibility tab and uncheck all the boxes.  It has also been reported that the problem can be overcome by editing the registry at HKEY_CLASSES_ROOT\Word.Document.12\shell\Open and deleting the ddeexec key.
    The ddeexec can also be deleted from
    HKEY_CLASSES_ROOT\Word.DocumentMacroEnabled.12\shell\Open.
    That fix is described at ...
    http://www.dilloway.co.uk/there-was-a-problem-sending-the-command.html
    It has been reported that uninstalling FastPictureView and FastPictureViewer Pro… overcomes the issue of the Minimize, Maximize, Close and Help buttons not being visible in Office 2013.
    If you have a Canon 8350 printer, try using the Canon MF8000 UFRI LT XPS driver as detail in the post by Riad Amstha on April 14 in the thread at:
    http://answers.microsoft.com/en-us/office/forum/office\_365hp-word/office-2013-crashes-with-canon-8350-printer/e2bf6530-92e0-47ef-b6ec-e803a91793d0?page=3#LastReply
    For the problem of nothing appearing when you start typing in a blank document in Word in Office 365 Home Premium, and you hear a bell sound with each keypress, but no characters appear, disable the SMARTInk add-in for an interactive whiteboard.
