Office 2013 Word Keeps Freezing (Not responding)
2013-04-02T16:00:21+00:00
I have just purchased Office 2013 and have used Word for a couple of minutes, but it repeatedly stops responding in specific scenarios.
It is far too buggy for me to migrate from my previous version of Office.
Situations in which it freezes:
  • Opening the options menu
  • On start up (when it claims that it is not the default program) - I fixed this one by making it the default program for everything
  • Closing the word document and choosing not to save
  • Scrolling through a very long document
Excel does not seem to have the same bugs, and I have successfully reached the options page on that program to turn off graphics acceleration.
The main reason I purchased Office 2013 was for Word and I would really like to have it functioning properly.
I am currently very disappointed and annoyed.
Other (possibly) relevant details
Platform: Windows 7
Other
Microsoft Office 2003
Microsoft 2010 Starter (pre-installed on laptop purchase)
Thanks for the help.
    2017-11-14T18:50:16+00:00
    Thanks, but I'm using office pro 2013. Does anyone know of fixes or workarounds for this issue? Workarounds for Word 2016 might work for 2013, and I'm willing to try just about anything at this point.
    Fortunately, I'll be leaving this company within a couple months, so I'll not have to deal with this much longer.  I've tried everything short of re-scratching the OS and reinstalling, but I'm hesitant to waste a couple of days to get back to a usable system, or four days to get my whole tool chain reinstalled.
    2017-12-24T17:44:34+00:00
    I have reloaded Word 3-4 times and it works for a while then after a couple days, it freezes when ever I try to open it . I'm a senior citizen. Why can it not work?
  3. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2017-12-24T21:16:20+00:00
    See the KnowledgeBase article "How to troubleshoot problems that occur when you start or use Word" at:
    https://support.microsoft.com/en-us/kb/921541
    or, see the Article “Why do I get a "stopped working message when I start my Office application at:
    http://office.microsoft.com/en-us/support/why-cant-i-start-my-office-2013-application-HA104011864.aspx
    Or
    https://support.microsoft.com/en-us/kb/3091375
    If that does not help, then you might remove all traces of the Office installation by downloading the fixit from the following article:
    http://support.microsoft.com/kb/2739501
    saving it to your computer and then running it.
    Then, after re-starting your computer, reinstall Office by logging into www.office.com/myaccountwith your registered email address and click Install Office.
    BEFORE REMOVING THE OFFICE INSTALLATION,  MAKE SURE THAT YOU ARE ABLE TO LOG INTO YOUR ACCOUNT AND THAT OFFICE IS ASSOCIATED WITH IT!
    If you actually have Office (locally installed) rather than the subscription version provided through Office 365, then you can't get Office through your Microsoft Account. Instead, see
    https://products.office.com/en-us/download-back-up-restore-microsoft-office-products
