I have just purchased Office 2013 and have used Word for a couple of minutes, but it repeatedly stops responding in specific scenarios.
It is far too buggy for me to migrate from my previous version of Office.
Situations in which it freezes:
- Opening the options menu
- On start up (when it claims that it is not the default program) - I fixed this one by making it the default program for everything
- Closing the word document and choosing not to save
- Scrolling through a very long document
Excel does not seem to have the same bugs, and I have successfully reached the options page on that program to turn off graphics acceleration.
The main reason I purchased Office 2013 was for Word and I would really like to have it functioning properly.
I am currently very disappointed and annoyed.
Other (possibly) relevant details
Platform: Windows 7
Other
Microsoft Office 2003
Microsoft 2010 Starter (pre-installed on laptop purchase)
Thanks for the help.
Update Windows Updates.
Restart your PC and run only Word.
Press for Task Manager:
Ctrl + Shift + Esc
Right click on unwanted program and select End task. In the Start section you can disabled the auto start programs.
It is advisable to run only one program at a time. In case of Word it consume around 1GB of RAM.
Or change the auto scanning schedule of antivirus if it clashes with Word.
Or do not explore you PC with too much heat of surrounding temperature, keep it in cool place.
Source:
https://answers.yahoo.com/question/index?qid=20160318201828AAkxYZd
