Userforms and VBA in Word 2007/2010 - Combobox with addresses
2012-02-09T23:44:33+00:00
I've been trying to get used to working with User forms, and I've gone as far as being able to create a form, but I am uncertain how to code it to work with a template.  I'm still waiting for some books to come in that I ordered to help me out, so in the mean time I'm looking for a little assistance from you amazing people :-)
The main thing I'm trying to work on is creating a combobox so that I can have a very long list that will continue to grow as I obtain more contacts.  I wanted to use dropdown form fields but realize I can't exceed 25 items per dropdown field.  I could use several dropdown fields to call the data from another document, but I'd like things to look clean.  So I think a combobox will be a much better option.  I want the combo box to have the names of all my contacts, and once a contact is selected, I want their entire mailing address to appear at the top of my letter template.
So let's say I select 'Option1' in the combo box, I'd like the top of my letter to show something resembling the following:
Recipient Name
Address
City, State/Province
Zip Code/Postal Code
I hope I've explained what I'd like done clearly enough, but if you require further explanation I'd be happy to provide.  If there's a better way to do this I'd be happy to hear it.
Thank you!
2012-02-10T07:04:41+00:00
The simplest solution, if you have it, is to use Outlook to both store the addresses and provide an address book dialog to insert the addresses where you require them. This is covered at http://www.gmayor.com/Macrobutton.htm.
If you want to list the addresses on a userform you will need a multi-column list box and somewhere to store the addresses - probably a document containing a table or perhaps an Excel worksheet, which can be read into the list box. Take a look at http://gregmaxey.mvps.org/word_tip_pages/Old_Tip_Pages/Populate_UserForm_ListBox.htm.
You can then populate a document variable with the contents of the selected item and use a docvariable field to reproduce the value from the docvariable in the document.
2012-02-16T08:44:29+00:00
Don't use bookmarks with a protected form, use a docvariable field in the document and write the value of the selected item from the list box to the variable. Then the protection becomes irrelevant.
If using a multi-column list box, then you will need to re compile the address from the list box columns in the format you require into the variable. Something like the following. I have set the listbox to display only the first column to avoid clutter.
Insert { DocVariable Address } into the document at the place you want the address to appear.
Option Explicit
Private oVars As Variables
Private oSource As Document
Private oTable As Table
Private oRng As Range
Private strWidth As String
Private i As Long, j As Long, k As Long
Private m As Long, n As Long
Private Sub UserForm_Initialize()
Set oSource = Documents.Open(FileName:="C:\Addresses.doc", _
                             AddToRecentFiles:=False, _
                             Visible:=False)
Set oTable = oSource.Tables(1)
'Get the number of list members (i.e., table rows - 1 if header row is used)
i = oTable.Rows.Count - 1
'Get the number of list member attributes (i.e., table columns)
j = oTable.Columns.Count
'Set the number of columns in the Listbox
With Me.ListBox1
    .ColumnCount = j
    strWidth = .Width - 2
    For k = 2 To j
        strWidth = strWidth & ";" & 0
    Next k
    .ColumnWidths = strWidth
    'Load list members into an array
    ReDim myArray(i, j)
    For n = 0 To j - 1
        For m = 0 To i - 1
            Set oRng = oTable.Cell(m + 2, n + 1).Range
            oRng.End = oRng.End - 1
            myArray(m, n) = oRng.Text
        Next m
    Next n
    'Populate the ListBox using the array
    .list() = myArray
    .ListIndex = 0
End With
'Close the source file
oSource.Close SaveChanges:=wdDoNotSaveChanges
End Sub
Private Sub CommandButton1_Click()
Set oVars = ActiveDocument.Variables
oVars("Address").Value = Me.ListBox1.Column(0) & vbCr & _
                         Me.ListBox1.Column(1) & vbCr & _
                         Me.ListBox1.Column(2) & vbCr & _
                         Me.ListBox1.Column(3)
ActiveDocument.Fields.Update
Unload Me
End Sub
42 additional answers
    2012-03-08T14:55:53+00:00
    I'm sorry, I can't seem to incorporate what's on your page with my current code.  I'm trying to use this one:
    Private Sub Userform_Initialize()
    'Late binding.  No reference to Excel Object required.
    Dim xlApp As Object
    Dim xlWB As Object
    Dim xlWS As Object
    Dim cRows As Long
    Dim i As Long
      Set xlApp = CreateObject("Excel.Application")
      'Open the spreadsheet to get data
      Set xlWB = xlApp.Workbooks.Open("D:\Data Stores\sourceSpreadsheet.xls")
      Set xlWS = xlWB.Worksheets(1)
      cRows = xlWS.Range("mySSRange").Rows.Count - xlWS.Range("mySSRange").Row + 1
      ListBox1.ColumnCount = 3
      'Populate the listbox.
      With Me.ListBox1
        For i = 2 To cRows
           'Use .AddItem property to add a new row for each record and populate column 0
          .AddItem xlWS.Range("mySSRange").Cells(i, 1)
          'Use .List method to populate the remaining columns
          .List(.ListCount - 1, 1) = xlWS.Range("mySSRange").Cells(i, 2)
          .List(.ListCount - 1, 2) = xlWS.Range("mySSRange").Cells(i, 3)
        Next i
      End With
      'Clean up
      Set xlWS = Nothing
      Set xlWB = Nothing
      xlApp.Quit
      Set xlApp = Nothing
    lbl_Exit:
      Exit Sub
    End Sub
    Below is my current code (Not sure if you would need to see the entire thing or just the initialize event so I copied everything below).  I would like to change oSource2 to use your example above.
    Option Explicit
    Private oSource1 As Document, oSource2 As Document
    Private Sub CmdBtnCancel_Click()
        Me.hide
    End Sub
    With ActiveDocument
        .Variables("Salutation").Value = Me.TextBox1.Text
        .Variables("Attention").Value = Me.TextBox2.Text
        .Variables("SentBy").Value = Me.TextBox3.Text
        .Variables("Period").Value = Me.TextBox4.Text
        .Variables("FileUnder").Value = Me.TextBox5.Text
        .Variables("Amount").Value = Me.TextBox6.Text
        .Fields.Update
      End With
     oVars("Address").Value = Me.ListBox1.Column(1) & vbCr & _
                              Me.ListBox1.Column(3) & vbCr & _
                              Me.ListBox1.Column(4)
     oVars("CFName").Value = Me.ListBox2.Column(0)
     oVars("CLName").Value = Me.ListBox2.Column(1)
     oVars("1").Value = Me.ListBox2.Column(2)
     oVars("2").Value = Me.ListBox2.Column(3)
     oVars("3").Value = Me.ListBox2.Column(4)
     oVars("4").Value = Me.ListBox2.Column(5)
     oVars("5").Value = Me.ListBox2.Column(6)
     oVars("6").Value = Me.ListBox2.Column(7)
     oVars("7").Value = Me.ListBox2.Column(8)
     oVars("8").Value = Me.ListBox2.Column(9)
     oVars("9").Value = Me.ListBox2.Column(10)
     oVars("10").Value = Me.ListBox2.Column(11)
     oVars("11").Value = Me.ListBox2.Column(12)
     oVars("12").Value = Me.ListBox2.Column(13)
     oVars("13").Value = Me.ListBox2.Column(14)
     oVars("14").Value = Me.ListBox2.Column(15)
     oVars("15").Value = Me.ListBox2.Column(16)
     oVars("16").Value = Me.ListBox2.Column(17)
     oVars("17").Value = Me.ListBox2.Column(18)
     oVars("18").Value = Me.ListBox2.Column(19)
    WriteTextToBM "Closing", Me.ListBox3.Column(1)
    WriteTextToBM "Name", Me.ListBox3.Column(0)
    WriteTextToBM "Position", Me.ListBox3.Column(3)
    InsertBBInBM "SigImage", Me.ListBox3.Column(2)
     Unload Me
    End Sub
    **Private Sub Userform_Initialize()**Set oSource1 = Documents.Open(FileName:="C:\Templates\TemplateDocs\Addresses.doc", _
                                  Visible:=False)
    Set oSource2 = Documents.Open(FileName:="C:\Templates\TemplateDocs\ClientInfo.doc", _
                                  Visible:=False)
    Set oTable = oSource1.Tables(1)
     With Me.ListBox1
          .ColumnCount = j
         For k = 2 To j
         Next k
         ReDim myArray(i, j)
         For n = 0 To j - 1
             For m = 0 To i - 1
             Next m
         Next n
         .List() = myArray
         .ListIndex = 0
     End With
     Set oTable = oSource2.Tables(1)
     With Me.ListBox2
     .ColumnCount = j 'The number of columns in the table
        strWidth = (.Width / 2) - 2 & ";" & (.Width / 2) - 2 'Set the first two column widths to suit the available space - you can use actual measurements if you prefer then to calculated measurements
        For k = 3 To j 'set columns 3 to the total to 0 width
        Next k
         ReDim myArray(i, j)
         For n = 0 To j - 1
             For m = 0 To i - 1
             Next m
         Next n
         .List() = myArray
         .ListIndex = 0
     oSource1.Close SaveChanges:=wdDoNotSaveChanges
     oSource2.Close SaveChanges:=wdDoNotSaveChanges
    End With
    Thank you!
    2012-03-09T07:35:36+00:00
    For just one text box using the whole of the sheet from A1 then the following should fit.
    Also unload your form rather than hide it when you click Cancel
    Dim xlApp As Object
    Dim xlWB As Object
    Dim xlWS As Object
    Dim cRows As Long
    Dim cCols As Long
    Dim i As Long
    Set xlWB = xlApp.Workbooks.Open("D:\My Documents\Test\Datasheet.xlsx")
    cRows = xlWS.Range("A65536").End(xlUp).Row
    cCols = xlWS.Cells(1, xlWS.Columns.Count).End(xlToLeft).Column
    ListBox1.ColumnCount = cCols
    With Me.ListBox1
        For k = 2 To cCols
        Next k
        For i = 2 To cRows
            .AddItem xlWS.Cells(i, 1)
            For j = 1 To cCols
                .list(.ListCount - 1, j) = xlWS.Cells(i, j + 1)
            Next j
        Next i
    End With
    Set xlWS = Nothing
    Set xlWB = Nothing
    xlApp.Quit
    Set xlApp = Nothing
    End Sub
    2012-03-09T18:40:17+00:00
    I get a compile error "Variable not defined" at this line:
    Here's what I have:
    Dim xlApp As Object
    Dim xlWB As Object
    Dim xlWS As Object
    Dim cRows As Long
    Dim cCols As Long
    Dim i As Long
    Set xlWB = xlApp.Workbooks.Open("C:\Templates\TemplateDocs\ClientInfo.xlsx")
    ListBox2.ColumnCount = cCols
    With Me.ListBox2
        For k = 2 To cCols
        Next k
        For i = 2 To cRows
            For j = 1 To cCols
                .List(.ListCount - 1, j) = xlWS.Cells(i, j + 1)
            Next j
        Next i
    End With
    Set xlWS = Nothing
    Set xlWB = Nothing
    xlApp.Quit
    Set xlApp = Nothing
    Set oSource1 = Documents.Open(FileName:="C:\Templates\TemplateDocs\Addresses.docx", _
                                  Visible:=False)
     With Me.ListBox1
          .ColumnCount = j
         For k = 2 To j
         Next k
         ReDim myArray(i, j)
         For n = 0 To j - 1
             For m = 0 To i - 1
             Next m
         Next n
         .List() = myArray
         .ListIndex = 0
     End With
    End Sub
