Userforms and VBA in Word 2007/2010 - Combobox with addresses
2012-02-09T23:44:33+00:00
I've been trying to get used to working with User forms, and I've gone as far as being able to create a form, but I am uncertain how to code it to work with a template.  I'm still waiting for some books to come in that I ordered to help me out, so in the mean time I'm looking for a little assistance from you amazing people :-)
The main thing I'm trying to work on is creating a combobox so that I can have a very long list that will continue to grow as I obtain more contacts.  I wanted to use dropdown form fields but realize I can't exceed 25 items per dropdown field.  I could use several dropdown fields to call the data from another document, but I'd like things to look clean.  So I think a combobox will be a much better option.  I want the combo box to have the names of all my contacts, and once a contact is selected, I want their entire mailing address to appear at the top of my letter template.
So let's say I select 'Option1' in the combo box, I'd like the top of my letter to show something resembling the following:
Recipient Name
Address
City, State/Province
Zip Code/Postal Code
I hope I've explained what I'd like done clearly enough, but if you require further explanation I'd be happy to provide.  If there's a better way to do this I'd be happy to hear it.
Thank you!
2012-02-10T07:04:41+00:00
The simplest solution, if you have it, is to use Outlook to both store the addresses and provide an address book dialog to insert the addresses where you require them. This is covered at http://www.gmayor.com/Macrobutton.htm.
If you want to list the addresses on a userform you will need a multi-column list box and somewhere to store the addresses - probably a document containing a table or perhaps an Excel worksheet, which can be read into the list box. Take a look at http://gregmaxey.mvps.org/word_tip_pages/Old_Tip_Pages/Populate_UserForm_ListBox.htm.
You can then populate a document variable with the contents of the selected item and use a docvariable field to reproduce the value from the docvariable in the document.
2012-02-16T08:44:29+00:00
Don't use bookmarks with a protected form, use a docvariable field in the document and write the value of the selected item from the list box to the variable. Then the protection becomes irrelevant.
If using a multi-column list box, then you will need to re compile the address from the list box columns in the format you require into the variable. Something like the following. I have set the listbox to display only the first column to avoid clutter.
Insert { DocVariable Address } into the document at the place you want the address to appear.
Option Explicit
Private oVars As Variables
Private oSource As Document
Private oTable As Table
Private oRng As Range
Private strWidth As String
Private i As Long, j As Long, k As Long
Private m As Long, n As Long
Private Sub UserForm_Initialize()
Set oSource = Documents.Open(FileName:="C:\Addresses.doc", _
                             AddToRecentFiles:=False, _
                             Visible:=False)
Set oTable = oSource.Tables(1)
'Get the number of list members (i.e., table rows - 1 if header row is used)
i = oTable.Rows.Count - 1
'Get the number of list member attributes (i.e., table columns)
j = oTable.Columns.Count
'Set the number of columns in the Listbox
With Me.ListBox1
    .ColumnCount = j
    strWidth = .Width - 2
    For k = 2 To j
        strWidth = strWidth & ";" & 0
    Next k
    .ColumnWidths = strWidth
    'Load list members into an array
    ReDim myArray(i, j)
    For n = 0 To j - 1
        For m = 0 To i - 1
            Set oRng = oTable.Cell(m + 2, n + 1).Range
            oRng.End = oRng.End - 1
            myArray(m, n) = oRng.Text
        Next m
    Next n
    'Populate the ListBox using the array
    .list() = myArray
    .ListIndex = 0
End With
'Close the source file
oSource.Close SaveChanges:=wdDoNotSaveChanges
End Sub
Private Sub CommandButton1_Click()
Set oVars = ActiveDocument.Variables
oVars("Address").Value = Me.ListBox1.Column(0) & vbCr & _
                         Me.ListBox1.Column(1) & vbCr & _
                         Me.ListBox1.Column(2) & vbCr & _
                         Me.ListBox1.Column(3)
ActiveDocument.Fields.Update
Unload Me
End Sub
42 additional answers
    2012-02-22T13:59:07+00:00
    Gah!!
    I was messing with just about everything except this to try and fix it.
    Only problem now is that it's taking the first and last column of the table, not the first and second.  I probably should have mentioned that there's a total of 20 columns in this table.  I assume this makes a difference in the code?
    Edit:
    I did this instead and it returned all the columns this time, which works well for me.
    strWidth = .Width / 2
         For k = j To 3
    But for future, can you please still show me if there's something to correct it to only display column 1 and 2 out of however many columns are in a table?
    Thanks!
    2012-02-22T15:22:13+00:00
    Actually there is an error in my code :(
    What the code attempts to do is display the column widths as half the available width for the first and second columns and zero for the rest. This worked fine for one column using all the available width, but I had not set the value of the second column.
    That's what comes with typing it rather than testing it - sorry :(
    You should find that
    With Me.ListBox1
        .ColumnCount = j 'The number of columns in the table
        strWidth = (.Width / 2) - 2 & ";" & (.Width / 2) - 2 'Set the first two column widths to suit the available space - you can use actual measurements if you prefer then to calculated measurements
        For k = 3 To j 'set columns 3 to the total to 0 width
        Next k
        .ColumnWidths = strWidth 'apply the widths string you have calculated.
    works better.
  3. Deleted
