Userforms and VBA in Word 2007/2010 - Combobox with addresses
2012-02-09T23:44:33+00:00
I've been trying to get used to working with User forms, and I've gone as far as being able to create a form, but I am uncertain how to code it to work with a template.  I'm still waiting for some books to come in that I ordered to help me out, so in the mean time I'm looking for a little assistance from you amazing people :-)
The main thing I'm trying to work on is creating a combobox so that I can have a very long list that will continue to grow as I obtain more contacts.  I wanted to use dropdown form fields but realize I can't exceed 25 items per dropdown field.  I could use several dropdown fields to call the data from another document, but I'd like things to look clean.  So I think a combobox will be a much better option.  I want the combo box to have the names of all my contacts, and once a contact is selected, I want their entire mailing address to appear at the top of my letter template.
So let's say I select 'Option1' in the combo box, I'd like the top of my letter to show something resembling the following:
Recipient Name
Address
City, State/Province
Zip Code/Postal Code
I hope I've explained what I'd like done clearly enough, but if you require further explanation I'd be happy to provide.  If there's a better way to do this I'd be happy to hear it.
Thank you!
2012-02-10T07:04:41+00:00
The simplest solution, if you have it, is to use Outlook to both store the addresses and provide an address book dialog to insert the addresses where you require them. This is covered at http://www.gmayor.com/Macrobutton.htm.
If you want to list the addresses on a userform you will need a multi-column list box and somewhere to store the addresses - probably a document containing a table or perhaps an Excel worksheet, which can be read into the list box. Take a look at http://gregmaxey.mvps.org/word_tip_pages/Old_Tip_Pages/Populate_UserForm_ListBox.htm.
You can then populate a document variable with the contents of the selected item and use a docvariable field to reproduce the value from the docvariable in the document.
2012-02-16T08:44:29+00:00
Don't use bookmarks with a protected form, use a docvariable field in the document and write the value of the selected item from the list box to the variable. Then the protection becomes irrelevant.
If using a multi-column list box, then you will need to re compile the address from the list box columns in the format you require into the variable. Something like the following. I have set the listbox to display only the first column to avoid clutter.
Insert { DocVariable Address } into the document at the place you want the address to appear.
Option Explicit
Private oVars As Variables
Private oSource As Document
Private oTable As Table
Private oRng As Range
Private strWidth As String
Private i As Long, j As Long, k As Long
Private m As Long, n As Long
Private Sub UserForm_Initialize()
Set oSource = Documents.Open(FileName:="C:\Addresses.doc", _
                             AddToRecentFiles:=False, _
                             Visible:=False)
Set oTable = oSource.Tables(1)
'Get the number of list members (i.e., table rows - 1 if header row is used)
i = oTable.Rows.Count - 1
'Get the number of list member attributes (i.e., table columns)
j = oTable.Columns.Count
'Set the number of columns in the Listbox
With Me.ListBox1
    .ColumnCount = j
    strWidth = .Width - 2
    For k = 2 To j
        strWidth = strWidth & ";" & 0
    Next k
    .ColumnWidths = strWidth
    'Load list members into an array
    ReDim myArray(i, j)
    For n = 0 To j - 1
        For m = 0 To i - 1
            Set oRng = oTable.Cell(m + 2, n + 1).Range
            oRng.End = oRng.End - 1
            myArray(m, n) = oRng.Text
        Next m
    Next n
    'Populate the ListBox using the array
    .list() = myArray
    .ListIndex = 0
End With
'Close the source file
oSource.Close SaveChanges:=wdDoNotSaveChanges
End Sub
Private Sub CommandButton1_Click()
Set oVars = ActiveDocument.Variables
oVars("Address").Value = Me.ListBox1.Column(0) & vbCr & _
                         Me.ListBox1.Column(1) & vbCr & _
                         Me.ListBox1.Column(2) & vbCr & _
                         Me.ListBox1.Column(3)
ActiveDocument.Fields.Update
Unload Me
End Sub
42 additional answers
    2012-04-09T06:48:20+00:00
    With all due respect to Hans, his is an answer to a different question to that addressed in this thread.
    If you want to populate 4 userform list boxes (which can have a maximum of 10 columns each) with the 35 columns from your table, display two columns in each and set the width of the form  (which is what you asked) then you would need something like
    Dim xlApp As Object
    Dim xlWB As Object
    Dim xlWS As Object
    Dim cRows As Long
    Dim cCols As Long
    Dim i As Long, j As Long, k As Long, m As Long
    Dim strWidth As String
    Set xlApp = CreateObject("Excel.Application")
    Set xlWB = xlApp.Workbooks.Open("C:\Templates\TemplateDocs\ClientInfo.xlsx")
    Set xlWS = xlWB.Worksheets(1)
    On Error GoTo CleanUp
    cRows = xlWS.Range("A65536").End(xlUp).Row
    cCols = 10
    Me.Width = 280 'Set the width of the form
    With Me.ListBox1
        .ColumnCount = cCols
        strWidth = Int((.Width / 2) - 2)
        strWidth = strWidth & ";" & strWidth
        For k = 2 To cCols
        Next k
        For i = 2 To cRows
            .AddItem xlWS.Cells(i, 1)
            For j = 1 To 9
                .list(.ListCount - 1, j) = xlWS.Cells(i, j + 1)
            Next j
        Next i
        .ListIndex = -1
    End With
    With Me.ListBox2
        For k = 2 To cCols
        Next k
        For i = 2 To cRows
            .AddItem xlWS.Cells(i, 10)
            For j = 10 To 19
                .list(.ListCount - 1, j - 10) = xlWS.Cells(i, j + 1)
            Next j
        Next i
        .ListIndex = -1
    End With
    With Me.ListBox3
        For k = 2 To cCols
        Next k
        For i = 2 To cRows
            .AddItem xlWS.Cells(i, 20)
            For j = 20 To 29
                .list(.ListCount - 1, j - 20) = xlWS.Cells(i, j + 1)
            Next j
        Next i
        .ListIndex = -1
    End With
    With Me.ListBox4
        For k = 2 To cCols
        Next k
        For i = 2 To cRows
            .AddItem xlWS.Cells(i, 30)
            For j = 30 To 34
                .list(.ListCount - 1, j - 30) = xlWS.Cells(i, j + 1)
            Next j
        Next i
        .ListIndex = -1
    End With
    CleanUp:
    Set xlWS = Nothing
    Set xlWB = Nothing
    xlApp.Quit
    Set xlApp = Nothing
    End Sub
    'The following will set the value selected in the first box in the rest.
    Private Sub ListBox1_Change()
    Me.ListBox2.ListIndex = Me.ListBox1.ListIndex
    Me.ListBox3.ListIndex = Me.ListBox1.ListIndex
    Me.ListBox4.ListIndex = Me.ListBox1.ListIndex
    End Sub
    2012-04-09T23:32:03+00:00
    Jumping in late in the thread, but I wanted to comment to clear something up.  The "10" column limit only applies when you are working with unbounded data sources.  If you have a bound data source then the limit is certainly more than 10.  I don't know what it really is but 35 is not a problem.
    You can run this code in a simple userform with two listboxes and a command button to demo:
    Option Explicit
    On Error Resume Next
    MsgBox Me.ListBox1.Column(34)
    Me.Hide
    End Sub
    'Create a bound data source
    Dim arrDemo(34, 1) As String
    Dim i As Long
    Dim j As Long
    'Populate the data source
    For i = 0 To 1
      For j = 0 To 34
        arrDemo(j, i) = "Row " & i + 1 & " Column " & j + 1
      Next j
    Next i
    'Set columns and populate
    Me.ListBox1.ColumnCount = UBound(arrDemo)
    Me.ListBox1.Column = arrDemo
    'Set columns (note no error)
    Me.ListBox2.ColumnCount = 34
    On Error GoTo Err_Handler
    For i = 0 To 1
      With Me.ListBox2
        .AddItem
        'Note error when j = 10
        For j = 0 To 34
          .Column(j, i) = "Test"
        Next j
      End With
    Next i
    Err_ReEntry:
    Exit Sub
    Err_Handler:
      MsgBox "It is only with unbounded data sources are you limited to " & j - 1 & " columns."
    Resume Err_ReEntry
    End Sub
    2012-04-10T02:09:01+00:00
    Another example of an unbound data source would be an Excel range:
    Dim xlApp As Object
    Dim xlbook As Object
    Dim xlSheet As Object
    Dim Listarray As Variant
    Dim bStartApp As Boolean
    Set xlApp = GetObject(, "Excel.Application")
    If Err Then
      bStartApp = True
    End If
    On Error GoTo 0
    With xlApp
      Set xlbook = .Workbooks.Open("D:\Data Stores\ClientInfo.xlsx") 'change as appropriate
      Set xlSheet = xlbook.Sheets(1)
      Listarray = xlSheet.UsedRange.Value
      xlbook.Close SaveChanges:=False
      Set xlbook = Nothing
    End With
    If bStartApp Then xlApp.Quit
    Set xlApp = Nothing
    With ListBox1
      .ColumnCount = UBound(Listarray, 2)
      .Clear
      .List() = Listarray
      .RemoveItem (0) 'removes any header row
    End With
    Set xlApp = Nothing
    Set xlSheet = Nothing
    End Sub
