Subscript Out of Range error when importing into Access 2007 from Excel.
2010-06-16T03:47:16+00:00
I have been importing Excel files for years. I recently upgraded to Access 2007 on a shared server (Windows Server 2003 R2, Service Pack 2) and now I can't import. Every time I get "Subscript out of Range" when I use the Import Wizard. The file is correct with the correct field names and data. I have tried importing into different tables and always get this error. I can try an .xls or an .xlsx file and neither work.
I have to paste the records in.
Help!
Microsoft 365 and Office | Access | For home | Windows
2010-09-03T16:30:08+00:00
  1. Just on a whim here, do you column headings use any Reserved Words (or
Wildcard Characters) that might confuse Access?
This was my problem. I had Serial# and # a few other places!
50 additional answers
    2012-08-08T11:26:24+00:00
    I experienced this issue today and resolved it by deleting extra lines and columns of my Excel file.
    Access was trying to create empty lines in my database.
    I selected lines under my data in Excel and right click + deleted it. Same with the columns.
    Hope it helps.
    Nunue
  2. Deleted
    2012-11-05T15:00:02+00:00
    I have this problem with a specific set of circumstances that may prove instructive:
    I upload a series of different excel 2007 sheets into their respective tables in access 2007.
    When I load sheets of the same # columns consecutively, they load fine. When I load sheets of varying columns the 1st sheet loads the next sheet with a varying column amount bugs out with the subscript error. Normally I simply exit and re-load access and continue loading sheets until it bugs again.
    (loading = importing below)
    HOWEVER today I tried something different. I loaded the first sheet per normal and tried sheet #2 with different columns. Bugged out. Re-loaded access.
    I then loaded sheet #2. Rather than load sheet #3, I ran other functions I normally use in access. THEN loaded sheet #3 (which ALWAYS bugs out after sheet #2).
    Didn't bug out.
    There is some reason you can't load consecutive sheets with differing column numbers even if going to different tables with the right respective columns for each.
    I tried all of the other suggestions and none of them worked until this one!  It is a little annoying to have to close and reopen the Access database between every data upload, but it definately beats any alternative i've tried.  Thanks!
    2012-11-08T15:33:15+00:00
    This is the most concise answer I've found to stop the 'subscript out of range error'
    It isn't a 'work around', it's a FIX
    http://www.judiwa.com/2010/09/13/access-2010-subscript-out-of-range-at-excel-data-import/
