Comment balloons will not print. WORD 2010
2011-10-25T22:05:21+00:00
Comment balloons will not print.  I have a document that has insertions and deletiions in the text and comments in balloons in the right margin.  When I try to print it, the space is there in the right hand marginto accomidate the ballons but the balloons don't print.  They show up in the Word Print Preview.
2014-01-15T14:08:17+00:00
This is a very old thread, but i'll post here as it's the top Google answer for 'word comments not printing.' I had this problem with a couple of users and i found the problem was that if a document is displayed in the Windows Explorer preview pane comments balloons won't print. With the preview pane disabled (or if you open the document from within Word, as others suggested), it will work.
If it has been opened in the preview pane you need to open task manager and kill winword.exe if it is running in order for it to work.
2012-05-17T17:55:05+00:00
Here's what works for me.  It is still annoying, but at least I can get the comments to print in the shaded area on the paper to match the print preview.  This works for me for printing to PDF, to a networked HP, and to a networked Xerox Mobile Express driver.  I hope it works for you, too.
  1. Close Word.
  2. Re-open Word.
  3. Using Word (not Windows Explorer), open the document.
  4. Print your file.  On the Print page, under Settings, click the button that holds the options like "Print all pages" and make sure that the "Print mark-up" is checked.
I've started doing a test run by printing 1 page to the printer "Adobe PDF", so I know the comment balloons are really printing. This keeps me from wasting paper and pricey color toner, and saves the interruption of a jog down the hall to the network printer.  Once I know the balloons are visible in the PDF, then I send the whole document to print on the network printer.
119 additional answers
    2016-08-03T22:16:06+00:00
    1. Close Word.
    2. Re-open Word.
    Combination of this response and one other worked.
    1. Save As - Rename the document
    2. Close Word
    3. Open the new document in Word
    4. Prints fine.
    2016-10-25T21:24:50+00:00
    I too had tried all of them. What worked for me was to turn OFF background printing.
    Go to options/advanced in the print section and uncheck print in background. This seems so far to work consistently. The other suggestions would work sometimes then stop working altogether.
    Hope this REALLY does work, not just another intermittent voodoo charm.
    I tried ALL other suggestions from this thread but unchecking 'background printing' helped!  I know this is an old thread, but wanted to say thank you as I've spent an inordinate amount of time to get comment bubbles to print for this one document.  Thanks again!
    2016-12-28T21:03:09+00:00
    ..."kill winword.exe"... was most helpful in my case. Once I ended it in task manager, I could print document with comments even from the preview pane as well as via opening in 'Word'.
