Comment balloons will not print. WORD 2010
2011-10-25T22:05:21+00:00
Comment balloons will not print.  I have a document that has insertions and deletiions in the text and comments in balloons in the right margin.  When I try to print it, the space is there in the right hand marginto accomidate the ballons but the balloons don't print.  They show up in the Word Print Preview.
2014-01-15T14:08:17+00:00
This is a very old thread, but i'll post here as it's the top Google answer for 'word comments not printing.' I had this problem with a couple of users and i found the problem was that if a document is displayed in the Windows Explorer preview pane comments balloons won't print. With the preview pane disabled (or if you open the document from within Word, as others suggested), it will work.
If it has been opened in the preview pane you need to open task manager and kill winword.exe if it is running in order for it to work.
2012-05-17T17:55:05+00:00
Here's what works for me.  It is still annoying, but at least I can get the comments to print in the shaded area on the paper to match the print preview.  This works for me for printing to PDF, to a networked HP, and to a networked Xerox Mobile Express driver.  I hope it works for you, too.
  1. Close Word.
  2. Re-open Word.
  3. Using Word (not Windows Explorer), open the document.
  4. Print your file.  On the Print page, under Settings, click the button that holds the options like "Print all pages" and make sure that the "Print mark-up" is checked.
I've started doing a test run by printing 1 page to the printer "Adobe PDF", so I know the comment balloons are really printing. This keeps me from wasting paper and pricey color toner, and saves the interruption of a jog down the hall to the network printer.  Once I know the balloons are visible in the PDF, then I send the whole document to print on the network printer.
119 additional answers
    2015-02-10T10:30:28+00:00
    For everyone who have this annoying issue. One workaround is as described, open the file with the "file -> open" command in word.
    For others, this issue comes from the "preview pane" of Windows Explorer(verified on Windows 7). Disable the preview pane in Windows Explorer and you can open the file through Windows Explorer, without the balloon error.
    2015-02-11T09:44:34+00:00
    I had this problem in the odious Word 2013 (that refuses to update, and deletes itself if you attempt to do so) and none of the many answers listed here worked. Here is what did:
    Review > Tracking >Options (in Word 2013, click the weeny little arrow at the lower right of the group)
    Select "Comments and Formatting" for "Balloons in All Markup View show". Previously it was set to "Nothing"
    Garry
    2015-03-13T06:50:17+00:00
    I tried all the tips here and didn't work initially.
    Then, finally I copy and paste into the new document, following the guidelines link posted by Stefan, and at the same time, doing all the charms and tips posted before.
    Finally it work.
    Thing the old doc got corrupted.. Best, copy and paste into new document, then click and un-check all the tips listed before:
    1. print marks up
    2. margin- normal
    3. change tracking option> paper orientation in printing > select Auto
    4. File> Option> Display> click print hidden text, uncheck print background
    Hope this help the others in misery..
    Thank you all for the valuable tips to help me through.
