Comment balloons will not print. WORD 2010
2011-10-25T22:05:21+00:00
Comment balloons will not print.  I have a document that has insertions and deletiions in the text and comments in balloons in the right margin.  When I try to print it, the space is there in the right hand marginto accomidate the ballons but the balloons don't print.  They show up in the Word Print Preview.
2014-01-15T14:08:17+00:00
This is a very old thread, but i'll post here as it's the top Google answer for 'word comments not printing.' I had this problem with a couple of users and i found the problem was that if a document is displayed in the Windows Explorer preview pane comments balloons won't print. With the preview pane disabled (or if you open the document from within Word, as others suggested), it will work.
If it has been opened in the preview pane you need to open task manager and kill winword.exe if it is running in order for it to work.
2012-05-17T17:55:05+00:00
Here's what works for me.  It is still annoying, but at least I can get the comments to print in the shaded area on the paper to match the print preview.  This works for me for printing to PDF, to a networked HP, and to a networked Xerox Mobile Express driver.  I hope it works for you, too.
  1. Close Word.
  2. Re-open Word.
  3. Using Word (not Windows Explorer), open the document.
  4. Print your file.  On the Print page, under Settings, click the button that holds the options like "Print all pages" and make sure that the "Print mark-up" is checked.
I've started doing a test run by printing 1 page to the printer "Adobe PDF", so I know the comment balloons are really printing. This keeps me from wasting paper and pricey color toner, and saves the interruption of a jog down the hall to the network printer.  Once I know the balloons are visible in the PDF, then I send the whole document to print on the network printer.
119 additional answers
  1. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2011-10-26T08:39:01+00:00
    You could use a macro such as the following to put the comments in-line in the document
    Dim acomment As Comment
    With ActiveDocument
        For Each acomment In .Comments
            With acomment
                .Reference.Shading.BackgroundPatternColor = wdColorViolet
                .Reference.Text = "[" & .Author & " - " & .Range.Text & "]"
            End With
        Next acomment
    End With
    2011-10-26T09:23:14+00:00
    Does it happen with a specific Word document or with the entire Word document which contain text and comments in balloons?
    Create a new Word document with comments in balloons and check if you are able to print?
    Try to change the default printer and check if you are able to print the same using a different printer.
    Refer the link below to set the default printer in windows.
    http://windows.microsoft.com/en-US/windows7/Change-your-default-printer
     If you are able to print fine using a different printer, contact the printer manufacturer for further help.
    You may refer to the link given below and check if it helps:
    http://office.microsoft.com/en-us/word-help/print-a-document-showing-tracked-changes-and-comments-HA001218974.aspx#BM3
    You may also refer to the link for frequently asked questions about comments in Word
    http://support.microsoft.com/kb/286169
    2011-11-01T15:02:06+00:00
    I do not want the comments in line as it disrupts reading of the text.  I want the balloons that I see on the screen to print.
