Word 2010 will not print images or text boxes
2011-03-08T21:00:27+00:00
I have a Word 2010 doc that will not print images or text boxes, of which the doc contains twenty or so. I have tried printing to different printers (different brands/models) in our office, to no avail. When printing to PDF (Acrobat Pro, not Word's built-in distiller), it works; so does doing a Save As using the built-in PDF distiller. Curiously, a single image in the doc does, in fact, print; it was imported from a 2003 doc (however, so were most of the other images that are not printing). In addition, I have a SmartArt component (org chart) that is printing fine.
Any suggestions on a solution are appreciated. Converting to PDF each time I need to print is tedious and should not be necessary when using the world's most popular word processor...
Thanks.
2011-03-08T23:27:59+00:00
I think you are correct. This does sound like a problem with the printer driver. Check to make sure that you have the latest driver and then delete and reinstall the printer.
53 additional answers
    2015-01-21T23:01:15+00:00
    2015 - January - Flow chart (text boxes, with color fill) not printing at all ... not the borders, nothing except the text within.  Tried on multiple printers.  All the settings were right and the only thing that finally worked was, yes, saving in Word 97-2003!  It is truly amazing that nothing has been done update-wise in all these years.
    2015-04-26T15:26:22+00:00
    Do the nonprinting images and text boxes show up in Print Preview? If not, then the problem is probably that you don't have "Print drawings created in Word" checked in File | Options | Display: Printing options. By "drawings" Word means anything in the drawing layer (as opposed to the text layer), which includes text boxes (usually) and wrapped graphics (those with a wrapping style other than In Line with Text). The one image that prints is probably inline.
    If all else fails, try saving the document as a PDF and print it if it views correctly.
    2015-08-03T17:59:10+00:00
    it fixed itself in 2013 but now the 2016 preview it is back.... same works for 2016.  saving as .doc and printing to pdf prints the images.
  4. Stefan Blom 353K Reputation points MVP Volunteer Moderator
    2015-08-03T18:48:18+00:00
    See http://wordfaqs.mvps.org/InvisibleGraphics.htm and possibly also http://wordfaqs.mvps.org/RedX.htm for a permanent fix.
