My situation for not being able to print pictures was this:
- Regardless of the printer selected, including PDF drivers & FAX, the pictures did not show when the Print options was selected from the File column.
- Under Options, Display, the "Print drawings created in Word(i) was already selected, thanks to a hint I took from this page last year, but this time that option didn't help,
Experimenting, this worked, but don't ask me why -- makes no sense
- Checked "Print Hidden Text"
Uh, "text"? Yeah, text. I've no idea what triggered this. Possible this is a factor:, wanted to float the picture away from its default position. In 2003, that ability was part of the picture properties. In 2010 its a "text" property,
I had to right-click the picture and change 'text wrap" to "Tight".
There's much one could infer here about the possible linkage of forcing a picture to be treated as "hidden text" in order to make the choices apply to actual graphics. One would hope there is not a linkage, and that a better way to fix this is available
for if I had actually been using hidden text, there probably would have been a reason for it.
TM
