Word 2010 blacking out numbering for Heading 3 in body and TOC
2011-06-08T17:59:36+00:00
My boss gave me a document to fix. Word 2010 has started blacking out (black box) the number for Heading 3 headers in the body and the TOC. I make the blocking go away by modifying the style numbering, but I can't get the numbering to work properly (won't let me set the numbering at X.X.X for Heading 3).
Has anyone seen this black-blocking on header level numbers (and do you know how to fix it)?
2011-08-16T10:52:02+00:00
And actually, here is a solution which works.
  1. Find a document which has the correct formatting in it.
  2. Save it as a template
  3. In the corrupted (for that is what it is) document go to the styles dialog box. The easiest way to do this is to use CTRL+ALT+SHIFT+S, otherwise you have to find your way through the poxy ribbon
  4. Hit the manage style button at the bottom of the box (right hand one of the three)
  5. Hit import/export
  6. in the right hand window of the box which appears, hit close file
  7. Now navigate to the uncorrupted document and select it.
  8. In the scroll box above navigate to the style you want to fix and click on it (single click)
  9. The copy arrow should now poin to the right, toward teh corrupt document
  10. Hit copy
  11. Say yes to everything
  12. Close all dialog boxes
This fixed it for me, hopefully it will work for you.
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2015-12-02T00:29:16+00:00
That may not be a permanent fix.
The problem occurs because the font characteristics in the list template have become corrupted and is best fixed by running a macro containing the following code:
For Each templ In ActiveDocument.ListTemplates
    For Each lev In templ.ListLevels
        lev.Font.Reset
    Next lev
Next templ
2011-06-08T22:22:40+00:00
See the article "How to create numbered headings or outline numbering in your Microsoft Word document" on the following page of fellow MVP Shauna Kelly's website:
http://www.ShaunaKelly.com/word/numbering/OutlineNumbering.html
If you create a template to hold your numbering scheme, you can use that template as the basis for new documents (using File > New) and the new documents will then inherit your numbering scheme. To do that, see:
Creating a Template - The Basics (Part I) at:
http://www.word.mvps.org/FAQs/Customization/CreateATemplatePart1.htm
and Creating a Template (Part II) at:
http://www.word.mvps.org/FAQs/Customization/CreateATemplatePart2.htm
100 additional answers
    2011-08-16T10:34:47+00:00
    "See the article "How to create numbered headings or outline numbering in your Microsoft Word document" on the following page of fellow MVP Shauna Kelly's website:"
    This is not the answer to the query. The problem is there is a bug in word which redacts numbers. Creating a new style or copying text into a clean drawing is not the solution. The solution is for MS to fix the problem methinks.
  2. Stefan Blom 352K Reputation points MVP Volunteer Moderator
    2011-08-16T11:28:49+00:00
    This fix suggests that the issue was list template (or possibly style) corruption.
