Word 2010 blacking out numbering for Heading 3 in body and TOC
2011-06-08T17:59:36+00:00
My boss gave me a document to fix. Word 2010 has started blacking out (black box) the number for Heading 3 headers in the body and the TOC. I make the blocking go away by modifying the style numbering, but I can't get the numbering to work properly (won't let me set the numbering at X.X.X for Heading 3).
Has anyone seen this black-blocking on header level numbers (and do you know how to fix it)?
2011-08-16T10:52:02+00:00
And actually, here is a solution which works.
  1. Find a document which has the correct formatting in it.
  2. Save it as a template
  3. In the corrupted (for that is what it is) document go to the styles dialog box. The easiest way to do this is to use CTRL+ALT+SHIFT+S, otherwise you have to find your way through the poxy ribbon
  4. Hit the manage style button at the bottom of the box (right hand one of the three)
  5. Hit import/export
  6. in the right hand window of the box which appears, hit close file
  7. Now navigate to the uncorrupted document and select it.
  8. In the scroll box above navigate to the style you want to fix and click on it (single click)
  9. The copy arrow should now poin to the right, toward teh corrupt document
  10. Hit copy
  11. Say yes to everything
  12. Close all dialog boxes
This fixed it for me, hopefully it will work for you.
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2015-12-02T00:29:16+00:00
That may not be a permanent fix.
The problem occurs because the font characteristics in the list template have become corrupted and is best fixed by running a macro containing the following code:
For Each templ In ActiveDocument.ListTemplates
    For Each lev In templ.ListLevels
        lev.Font.Reset
    Next lev
Next templ
2011-06-08T22:22:40+00:00
See the article "How to create numbered headings or outline numbering in your Microsoft Word document" on the following page of fellow MVP Shauna Kelly's website:
http://www.ShaunaKelly.com/word/numbering/OutlineNumbering.html
If you create a template to hold your numbering scheme, you can use that template as the basis for new documents (using File > New) and the new documents will then inherit your numbering scheme. To do that, see:
Creating a Template - The Basics (Part I) at:
http://www.word.mvps.org/FAQs/Customization/CreateATemplatePart1.htm
and Creating a Template (Part II) at:
http://www.word.mvps.org/FAQs/Customization/CreateATemplatePart2.htm
100 additional answers
    2014-06-16T23:23:45+00:00
    THANK YOU SO MUCH - MADDENING PROBLEM, BUT THIS SOLVED FOR ME. SHAME ON MICROSOFT FOR TOLERATING THIS BUG SO LONG! (USING WORD 2013)
    2014-07-20T21:48:50+00:00
    I spent around 5 hours trying to fix this problem and was close to pulling my hair out. I tried every fix suggested (creating new multi lists and importing uncorrupted styles etc) and the problem kept returning.
    The below seems to have worked for me and I hope it's a permanent solution
    1. Firstly I did the following as has been suggested by a number of users
    2. Put your cursor on the heading just right of the black box
    3. Use the left arrow key on your keyboard to move left until the black box turns grey
    4. Use the keyboard combination ctrl+shift+s, the dialog "Apply Styles" should appear
    5. In this box, click "reapply"
    6. Once the black boxes had disappeared I saved the document as a word 1997-2003 document (document 2).
    7. I resaved document 2 as a normal word document (2013 in my case) and selected the compatibility mode option when saving (document 3)
    8. I resaved document 3 as a word document (2013) and deselected the compatibility mode option (document 4).
    It seems to have worked and the black boxes have disappeared. I hope this is a permanent fix otherwise I will go back to working on document 2 (word 2003 version).
