Conditional fomatting formula to match positive and negative amounts in a single column.
2010-07-24T15:40:02+00:00
I have a single column of both positive and negative amounts.  I am looking for a formula to insert in the conditional formatting option that will show a "strikethrough" effect for those that match.  I have inserted another column and added the absolute function to those amounts, sorted them, and used the "countif" formula, strikethrough effect in the conditional formatting to accomplish this.  However, I was wondering if I could accomplish this without adding this second column.
Thanks for looking at my request.
2010-07-24T22:44:02+00:00
The following code will, I believe, do what you need:
Sub OffsetFound()
    Dim I As Long
    Dim last As Long
    Dim cell As Range
    last = Selection.Row + Selection.Count - 1
    For Each cell In Selection
        With cell
            If .Font.Strikethrough = False Then
            I = 1
                Do
                    If .Offset(I, 0) = -cell And .Offset(I, 0).Font.Strikethrough = False Then
                        .Font.Strikethrough = True
                        .Offset(I, 0).Font.Strikethrough = True
                        Exit Do
                    End If
                    I = I + 1
                Loop Until .Offset(I, 0).Row > last
            End If
        End With
    Next cell
End Sub
If this answer solves your problem, please check, Mark as Answered. If this answer helps, please click the Vote as Helpful button. Cheers Shane Devenshire
2010-07-25T16:00:26+00:00
Unless I am implementing Teethless mama's conditional formatting formula incorrectly, it (and all the posted variations derived from it) appears to only "strike through" the first of the positive/negative paired values... the solution by Mike H does the "strike through" to both the positive and negative values.
I have no problem to get the formatting as expected, i.e. striking out positive and negative values "pairwise" leaving any unmatched unformatted.
Here is an example of data and formatting (red background used instead of strikethrough for readability reasons) using the formatting formula:
=SMALL(IF($A$2:$A$21=-A2,1),COUNTIF($A$2:A2,A2))
Regards / Lars-Åke
2010-07-24T23:00:24+00:00
Sub OffsetFound()
    Dim I As Long
    Dim last As Long
    Dim cell As Range
        With cell
            I = 1
                Do
                        Exit Do
                    End If
                    I = I + 1
            End If
        End With
    Next cell
End Sub
If this answer solves your problem, please check, Mark as Answered. If this answer helps, please click the Vote as Helpfulbutton. Cheers Shane Devenshire
I suggest that you put in a clearing of strike throughs at the beginning if you want to run the macro again after changing some data in the selected range.
For each cell in Selection
   cell.Font.Strikethrough = False
Next cell
Regards / Lars-Åke
2010-07-24T21:16:04+00:00
Rob,
Select the range and apply this conditional format using font strikethrough and I think this does what you want in a single column
=COUNTIF($A$1:$A$11,A1)+COUNTIF($A$1:$A$11,-1*A1)=2
If this post answers your question, please mark it as the Answer.
Mike H
49 additional answers
    2010-07-25T15:47:24+00:00
