How do i recover a document saved directly from download?
2010-04-22T22:35:08+00:00
I sent my university coursework to a friend to proof read it. He sent it back with amendments, and i clicked on the attached file in hotmail, and continued working on it, clicking save every few minutes.
However i did not click SAVE AS, and so when i closed the document just now, my entire days work was lost, as it appears to have saved no where. Where had it been saving for the whole day? Can i recover it?
Im currently on windows vista and word 2007.
John
2010-04-22T23:59:43+00:00
You may or may not be able to recover this document since the changes are saved in your Temporary Internet files folder. Note that you can't just open your Temporary Internet Files folder directly and find it due to the way Windows handles your Temporary Internet files but if it's still available, here's how you can get it back:
  1. Open another Word document sent to you as an attachment from an email. If you don't have one, send an email with an
attachment to yourself. (While you should be able to open the same email attachement since another copy of the file is created in your Temporary Internet Files folder, I don't like taking a chance like that.) 2. Click the Office Button, point at Prepare, and then click Properties. The Properties pane will display below the Ribbon. 3. On the far right of the Properties pane you'll see a file path and the document name. Select only the file path and press Ctrl + C to copy it. 4. Press the WinKey + E to open the Windows Explorer. (Or use an alternate method to open it) 5. Paste the copied file path in the Address bar and press Enter.
These steps should put you either in the same location as your revised file or near it. You may need to dig around in other folders to locate it.
Good luck and I'll keep my fingers crossed for you. :-)
~Beth Melton Microsoft Office MVP
66 additional answers
    2010-05-28T17:35:54+00:00
    Everyone - I don't have Outlook, I run Microsoft Office 2003, Yahoo Mail, and Windows XP.  I have done everything listed here before even posting on this site as I'm aware of every solution presented.  My Temporary Internet Files have not been cleared or deleted in MONTHS and I have not even rebooted the drive.  Does anyone have the expertise to discuss manual file restoration?  I find it hard to believe that something would cease to exist seconds after it was last saved/modified.  The kernel, RAM, Cache and possibly even the HD must have a trace of it somewhere or edits would not have been permitted in the first place and saves would have failed.
    I need some hard core advice, please do not refer to any prior strings of this post as I have read them all, could have written all of them and none of them are helpful.
    2010-05-28T19:41:47+00:00
    I verified if you open an attachment from a Yahoo email account that you can access it using the steps provided. Since you were unable to find a folder named "JZ15H8YB" in your Content.IE folder that suggests it was either deleted or you’re not accessing it using the copy/paste method in the Address bar of the Windows Explorer. I’ve found you can’t access this location directly – you need to backdoor into it. But there’s no guarantee you'll be able to find it -- it's just something you can try and you might get lucky.
    As for a trace of it remaining on your HD, the methods in the KB article I provided in my previous reply are really all there is. Unfortunately, the real computer world doesn't work like you see on TV. :-(
    2010-05-28T20:55:22+00:00
    I live in the "real" computer world and am actually a professional in the IT arena but this is not my particular forte.  And I have tried copy/paste as you suggest.  I have even routed to the same drive via MS Dos commands.  I did not "delete" anything and I am aware of the steps needed to save the file from Yahoo mail, in fact I have tested a 2nd file in the same exact manner and it was saved to a Temporary Internet Directory that I have been able to successfully retrieve.  Please try again.
    2010-05-28T22:44:10+00:00
    I'm sorry, but I already gave you everything I know to try and that's backdooring into your TIP folder and the KB article that may locate the file or turn up a remnant of it. If you used Save As, perhaps it wasn't saved in your TIF folder and you saved it in a folder that's not indexed for Search.
