How do i recover a document saved directly from download?
2010-04-22T22:35:08+00:00
I sent my university coursework to a friend to proof read it. He sent it back with amendments, and i clicked on the attached file in hotmail, and continued working on it, clicking save every few minutes.
However i did not click SAVE AS, and so when i closed the document just now, my entire days work was lost, as it appears to have saved no where. Where had it been saving for the whole day? Can i recover it?
Im currently on windows vista and word 2007.
John
2010-04-22T23:59:43+00:00
You may or may not be able to recover this document since the changes are saved in your Temporary Internet files folder. Note that you can't just open your Temporary Internet Files folder directly and find it due to the way Windows handles your Temporary Internet files but if it's still available, here's how you can get it back:
  1. Open another Word document sent to you as an attachment from an email. If you don't have one, send an email with an
attachment to yourself. (While you should be able to open the same email attachement since another copy of the file is created in your Temporary Internet Files folder, I don't like taking a chance like that.) 2. Click the Office Button, point at Prepare, and then click Properties. The Properties pane will display below the Ribbon. 3. On the far right of the Properties pane you'll see a file path and the document name. Select only the file path and press Ctrl + C to copy it. 4. Press the WinKey + E to open the Windows Explorer. (Or use an alternate method to open it) 5. Paste the copied file path in the Address bar and press Enter.
These steps should put you either in the same location as your revised file or near it. You may need to dig around in other folders to locate it.
Good luck and I'll keep my fingers crossed for you. :-)
~Beth Melton Microsoft Office MVP
66 additional answers
    2010-04-23T00:12:11+00:00
    Hey Beth,
    Well we have partial success! It has found an old save of it, but unfortunately not the most recent! That saves me at least 2 hours work though! Thank you very much! Ill continue looking around in the folders, but since everything else I've tried has pulled up nothing, I think this might be as good as I'll get.
    Thanks again for the clear and helpful advice,
    John
    2010-04-23T00:29:15+00:00
    You're welcome and I'm glad to hear you got at least some of it back. :-) But if you found some of it and you know you saved your changes then a more current copy might be there. But if you can't find one, hopefully since you know the changes you made it won't take as long to redo them.
    2010-05-10T20:34:58+00:00
    Beth,
    I am having a very similar problem - but i dont understand the instructions above? Can you tell me where the office button is, or am i being stupid?
    Kind Regards
    Jamie
    2010-05-10T20:36:58+00:00
    The instructions are for Word 2007. What version of Word are you using?
