Auto Enter County, State & Zip after entering City
2010-12-27T19:38:00+00:00
I'm trying to make data entry easier. We have a relatively small client base (3 counties) and I'm wondering if I create a table with all of the cities in the counties grouped together with states and zips if Access will be able to AutoEnter the County, State and Zip after the City is entered?
(I've only got beginner Access 2010 under my belt....hoping they will send me to level 2 at the very least...)
THANKS so very much for your time!
Microsoft 365 and Office | Access | For home | Windows
    2010-12-28T01:18:43+00:00
    Scottgem [MVP] wrote in
    news:*** Email address is removed for privacy ***
    m:
    Actually its just the opposite. A relational database makes data
    entry EASIER because you don't have to enter redundant info. Yes
    you enter the zip code in your main data table. And that's all you
    enter. To see the County State, Town you do a join to your zip
    code table. If you look at the blog I mentioned it may help you
    understand this better.
    I'm going to call foul here on this one because I've never once
    implemented a data structure that assumes that a zip code can be
    used to populate the city and state fields. For one, you may not
    have the zip code. Secondly, a single zip code can cover multiple
    cities (though never multiple states).
    To me, implementing it the way you suggest would be
    overnormalization and I've never seen an application implemented
    that way.
    I'm surprised so many people are even beginning to suggest this!
    David W. Fenton                  http://www.dfenton.com/ contact via website only     http://www.dfenton.com/DFA/
    2010-12-28T01:21:22+00:00
    HansV MVP wrote in
    m:
    There can be multiple zip codes for a city, so you can't
    automatically fill in the zip code once a city has been entered or
    selected.
    But you also can't go the other way, as a single zip code can cover
    multiple cities/municipalities.
    This is a case where I don't really think there's a practical way to
    normalize the structure the way everybody is suggesting. I always
    store city/state/zip because these are not attributes that are 100%
    dependent on each other. In an ideal world they would be, but in
    reality, they are not.
    2010-12-28T02:24:29+00:00
    I'm going to have to correct you here and inform you that Zip Codes do not cross city boundaries.  Check with the postal service or refine your research on this one.
    Furthermore, this demonstration was not intended to imply that the OP should build his system to my specification.  This is merely to present an example of normalization.
    2010-12-28T04:10:05+00:00
    Umm, yes it can.  I gave you a specific answer.  Seatac, Washington and Tukwila, Washington share the 98188 zip code.  So you have two incorporated cities which use the same zip code.  How do I know that?  Because I used to live in both.  And if YOU will do the research - look for McDonald's Restaurant at
    15210 PACIFIC HWY W
    TUKWILA  WA  98188
    and 7-11 in Seatac
    3120 SOUTH 176TH ST
    SEATAC,WA 98188
    Bob Larson, Former Access MVP (2008-2010) http://www.btabdevelopment.com (free Access tools, tutorials, and samples)
    2010-12-28T04:30:27+00:00
    Bob, what can I say I guess you have me over a barrel.  I've done extensive research in this area and though I'm still no expert, Zip Codes are not commonly found to cross city boundaries.  SEATAC became a city in 1989 and that might explain why there is some ambiguity there.  I really don't have an answer.  The Zip Code alone when referenced is a Seattle locale.
