How do I keep the ribbon always visible?
2011-03-16T22:54:08+00:00
When I am in a Word doc and want to, e.g., change the font, I have to click on Home, then font size.  Afterwards, the ribbon disappears.  If I want to do any other formatting, I again have to click on Home, etc.
When I first started using Word in 2010 Starter, the ribbon was always visible; I would like that again.
Jay Freedman 208.3K Reputation points Volunteer Moderator
2011-03-17T00:38:03+00:00
The ribbon is "minimized". There are three ways to "unminimize" it:
  • Press Ctrl+F1 (this is an on/off toggle).
  • Double-click any of the tabs (Home, View, etc.).
  • Right-click any of the tabs or the Quick Access Toolbar and uncheck "Minimize the ribbon". Edit: In Office 2013, there's an additional way. The icon (shown below by the red box) in the top right corner of the window has a dropdown menu. Click Show Tabs and Commands to see the full ribbon. The Auto-hide Ribbon choice is new -- it hides both the tabs and the buttons to give you the most reading/editing space for the document. To show the ribbon temporarily, click once at the top of the window. As soon as you click a button on the ribbon, it will hide again. To turn this off, click the icon and click one of the other two choices.
2012-03-27T20:23:12+00:00
If you expand the ribbon by any of the methods I listed above, it should stay expanded until you do the reverse of one of those methods. The state should stay unchanged even if you shut down and restart Word or Windows.
If that isn't happening for you, there are a couple of possibilities: There may be an add-in that's improperly changing the ribbon's visibility, or there may be a problem in the registry that prevents the ribbon's state from being saved. Neither of these is very likely.
46 additional answers
  1. Charles Kenyon 171.1K Reputation points Volunteer Moderator
    2017-09-21T22:40:06+00:00
    Ctrl-F1 does nothing.
    Double-click on tabs does nothing, as there are no tabs.
    Clicking a Quick Access Toolbar does nothing, as there is no Quick Access Toolbar.
    How do I get the menu back now?
    That is because you are responding to an old thread about older versions of Word. Word 2016 upped the difficulty.
    In the top right corner of your Word window, is a little control. You want to choose to show tabs and commands.
    2017-09-22T21:37:53+00:00
    if you read my original question, I know how to do this. It works correctly on most machines.  i have one where it appears to work and after some time passes, like a day or two, it closes again. This feature is sticky on all other machines, just not this one.
    we have 180 machines with identical add-ins, none of the rest have this problem.
    which registry keys might be causing this?
    2017-11-10T16:22:43+00:00
    The "Show Ribbon tabs and commands all the time" is bogus as the Emperor's new clothes. Why do people like this keep their heads in the sand and continue to promulgate their hogwash/misunderstood ideas. It don't "Show all the  time". Period. Where can we find one of the army of Microsoft programmers whose job it is to diagnose and fix stuff like this? The stuff of which was paid good money for.
