COUNTIF on cell color
2010-11-01T12:09:13+00:00
Within Excel, I have a matrix of programs horizontally and accounts vertically and I have evaluated the performance of each intersection of the maxtrix with red (has concerning issues), yellow (has some issues), and green (no issues). At the bottom of my matrix, I'd like to use a COUNTIF formula to count the number of cells that are red, yellow, and green. What's the best way to COUNTIF on cell color? If needed, I can create a separate matrix that identifies the cell color by number (red,green,blue combination) and then do a lookup on that matrix.
Scott
2010-11-01T12:16:18+00:00
Excel has no native way of doing this so we must create a UDF to do it. ALT+F11 to open vb editor, right click 'ThisWorkbook' and insert module and paste the code below in. Close VB editor.
Back on the worksheet call with
=Countcolour($A$1:$J$1,K1)
Where:-
A1:J1 is the range you want to count
K1 is a cell with the fill colour you want to count.
Function Countcolour(rng As Range, colour As Range) As Long
Dim c as Range
Application.Volatile
For Each c In rng
    If c.Interior.ColorIndex = colour.Interior.ColorIndex Then
        Countcolour = Countcolour + 1
    End If
Next
End Function
If this post answers your question, please mark it as the Answer.
Mike H
2010-11-01T12:34:16+00:00
To expand on HansV (and MikeH's) comments... You might consider using the same criteria that you used to set the colors to count them.  If you used conditional formatting to color them, then use the same criteria to get a count of them using either SUMPRODUCT() [works for all versions of Excel], or COUNTIFS() [Excel 2007 & later only] to get a count.
Here are 3 example formulas assuming a list of integers in cells from A2:A7 that you want to count the cells in that are:
  1. greater than zero, but less than 11 (i.e. 1-10) (perhaps your RED cells)
  2. greater than 10, but less than 21 (i.e. 11-20) (perhaps your YELLOW cells)
  3. greater than 20, but less than 31 (i.e. 21-30) (perhaps your GREEN cells)
Using SUMPRODUCT():
=SUMPRODUCT(--(A2:A7>0),--(A2:A7<11))
=SUMPRODUCT(--(A2:A7>10),--(A2:A7<21))
=SUMPRODUCT(--(A2:A7>20),--(A2:A7<31))
Equivalent using SUMIFS()
=COUNTIFS(A2:A7,">0",A2:A7,"<11")
=COUNTIFS(A2:A7,">10",A2:A7,"<21")
=COUNTIFS(A2:A7,">20",A2:A7,"<31")
I am free because I know that I alone am morally responsible for everything I do. R.A. Heinlein
52 additional answers
    2014-08-06T11:31:11+00:00
    Hi Eric,
    Am I right in thinking your function works if there is only one CF rule applied? I was trying it on a range that has 3 rules and getting some unexpected answers.
    _______________
    Regards, Tom
    2014-08-06T14:11:42+00:00
    Tom,
    If you can provide me an example scenario, I'll test it and see.  I didn't (and probably cannot) try to imagine every possible application of CF, so I'm sure I missed many possibilities!
    As I said in my previous post, I am thinking of updating the code, so this might be a good time to fix any glitches.
    Eric
    2014-08-06T18:10:43+00:00
    Hi Eric,
    No criticism was intended. I can imagine trying to accommodate all possible CF's would be formidable (if not impossible)!
    I was trying the Count option (4), with A1 as the control, and C3:C12 as test range.
    A1 and C3:C12 all have same CF applied (examples shown for A1):
    rule 1, formula applied: =ISNUMBER(A1) (format, fill yellow), STOP IF TRUE
    rule 2, formula applied: =ISTEXT(A1) (format, fill blue), STOP IF TRUE
    rule 3, formula applied: =ISBLANK(A1) (format, fill green)
    C3:C12 contains a mix of numbers, text, blanks.
    Function was entered in C15
    By having A1 as containing either number, text or blank I got a few unexpected returns in C15
    _______________
    Regards, Tom
