COUNTIF on cell color
2010-11-01T12:09:13+00:00
Within Excel, I have a matrix of programs horizontally and accounts vertically and I have evaluated the performance of each intersection of the maxtrix with red (has concerning issues), yellow (has some issues), and green (no issues). At the bottom of my matrix, I'd like to use a COUNTIF formula to count the number of cells that are red, yellow, and green. What's the best way to COUNTIF on cell color? If needed, I can create a separate matrix that identifies the cell color by number (red,green,blue combination) and then do a lookup on that matrix.
Scott
2010-11-01T12:16:18+00:00
Excel has no native way of doing this so we must create a UDF to do it. ALT+F11 to open vb editor, right click 'ThisWorkbook' and insert module and paste the code below in. Close VB editor.
Back on the worksheet call with
=Countcolour($A$1:$J$1,K1)
Where:-
A1:J1 is the range you want to count
K1 is a cell with the fill colour you want to count.
Function Countcolour(rng As Range, colour As Range) As Long
Dim c as Range
Application.Volatile
For Each c In rng
    If c.Interior.ColorIndex = colour.Interior.ColorIndex Then
        Countcolour = Countcolour + 1
    End If
Next
End Function
If this post answers your question, please mark it as the Answer.
Mike H
2010-11-01T12:34:16+00:00
To expand on HansV (and MikeH's) comments... You might consider using the same criteria that you used to set the colors to count them.  If you used conditional formatting to color them, then use the same criteria to get a count of them using either SUMPRODUCT() [works for all versions of Excel], or COUNTIFS() [Excel 2007 & later only] to get a count.
Here are 3 example formulas assuming a list of integers in cells from A2:A7 that you want to count the cells in that are:
  1. greater than zero, but less than 11 (i.e. 1-10) (perhaps your RED cells)
  2. greater than 10, but less than 21 (i.e. 11-20) (perhaps your YELLOW cells)
  3. greater than 20, but less than 31 (i.e. 21-30) (perhaps your GREEN cells)
Using SUMPRODUCT():
=SUMPRODUCT(--(A2:A7>0),--(A2:A7<11))
=SUMPRODUCT(--(A2:A7>10),--(A2:A7<21))
=SUMPRODUCT(--(A2:A7>20),--(A2:A7<31))
Equivalent using SUMIFS()
=COUNTIFS(A2:A7,">0",A2:A7,"<11")
=COUNTIFS(A2:A7,">10",A2:A7,"<21")
=COUNTIFS(A2:A7,">20",A2:A7,"<31")
I am free because I know that I alone am morally responsible for everything I do. R.A. Heinlein
52 additional answers
    2011-09-13T23:29:00+00:00
    If you have not already posted this as a separate question of its own, you should do so.  It's not going to get much attention in this year-old discussion.
    2011-10-26T11:56:58+00:00
    Hi Mike H,
    Many thanks for this code below.
    Please can you tell me what I need to do to the vb code to amend is so that it will count the colours after conditional formatting has taken place?
    Basically, all cells are red, unless they have been conditionally formatted to Green, Yellow or Orange... And this function counts only the red squares.
    For example, I have a range of 30 cells (A3 to AG3) which all start red, but after formatting I have 8 green, 1 yellow, 10 orange and 11 red.. When I use the function to count for each colour, I get 0 for all except the red which gives 30.
    Any ideas?
    =Countcolour($A$1:$J$14,K1)
    Where:-
    Dim c as Range
    For Each c In rng
        End If
    Next
    End Function
    Mike H
    2011-10-26T12:37:16+00:00
    Jonathan G-S, VBA can't directly test to see if the results of conditional formatting have set the shading of a cell.  You have to test using the same kind of "math" logic you use in the formulas that define the conditions that result in the different formatting be applied.  See my post on using SUMPRODUCT() to do that kind of thing.  Your VBA code is going to have to emulate the testing of the cell's contents and keep count of those cells where the different results of the tests are true.
