COUNTIF on cell color
2010-11-01T12:09:13+00:00
Within Excel, I have a matrix of programs horizontally and accounts vertically and I have evaluated the performance of each intersection of the maxtrix with red (has concerning issues), yellow (has some issues), and green (no issues). At the bottom of my matrix, I'd like to use a COUNTIF formula to count the number of cells that are red, yellow, and green. What's the best way to COUNTIF on cell color? If needed, I can create a separate matrix that identifies the cell color by number (red,green,blue combination) and then do a lookup on that matrix.
Scott
2010-11-01T12:16:18+00:00
Excel has no native way of doing this so we must create a UDF to do it. ALT+F11 to open vb editor, right click 'ThisWorkbook' and insert module and paste the code below in. Close VB editor.
Back on the worksheet call with
=Countcolour($A$1:$J$1,K1)
Where:-
A1:J1 is the range you want to count
K1 is a cell with the fill colour you want to count.
Function Countcolour(rng As Range, colour As Range) As Long
Dim c as Range
Application.Volatile
For Each c In rng
    If c.Interior.ColorIndex = colour.Interior.ColorIndex Then
        Countcolour = Countcolour + 1
    End If
Next
End Function
If this post answers your question, please mark it as the Answer.
Mike H
2010-11-01T12:34:16+00:00
To expand on HansV (and MikeH's) comments... You might consider using the same criteria that you used to set the colors to count them.  If you used conditional formatting to color them, then use the same criteria to get a count of them using either SUMPRODUCT() [works for all versions of Excel], or COUNTIFS() [Excel 2007 & later only] to get a count.
Here are 3 example formulas assuming a list of integers in cells from A2:A7 that you want to count the cells in that are:
  1. greater than zero, but less than 11 (i.e. 1-10) (perhaps your RED cells)
  2. greater than 10, but less than 21 (i.e. 11-20) (perhaps your YELLOW cells)
  3. greater than 20, but less than 31 (i.e. 21-30) (perhaps your GREEN cells)
Using SUMPRODUCT():
=SUMPRODUCT(--(A2:A7>0),--(A2:A7<11))
=SUMPRODUCT(--(A2:A7>10),--(A2:A7<21))
=SUMPRODUCT(--(A2:A7>20),--(A2:A7<31))
Equivalent using SUMIFS()
=COUNTIFS(A2:A7,">0",A2:A7,"<11")
=COUNTIFS(A2:A7,">10",A2:A7,"<21")
=COUNTIFS(A2:A7,">20",A2:A7,"<31")
I am free because I know that I alone am morally responsible for everything I do. R.A. Heinlein
52 additional answers
    2016-02-09T18:21:28+00:00
    Thank you Mike H.  This was my solution!
    2016-02-24T01:12:25+00:00
    This worked - thanks! However, it only worked for a one time count ... wierd. So, if I made a change and highlighted additional cells it did not count those. I had to refresh the formula cell by opening it and pressing enter. Is their a way to fix this? I am a beginner as you may have guessed. And yes, I should not be using 2003 if that matters.
    I'm afraid there's little you can do about that because changing the colour of a cell doesn't force Excel to re-calculate. You can force calculation by tapping F9.
    I have read the entire string but no where does the COUNTIF function show... I need to use it when I filter and it updates based on the COUNTIF criteria.
    Example:
    Here is the VB:
    Function GetCellColor(xlRange As Range)
        Dim indRow, indColumn As Long
        Dim arResults()
        If xlRange Is Nothing Then
            Set xlRange = Application.ThisCell
        End If
        If xlRange.Count > 1 Then
          ReDim arResults(1 To xlRange.Rows.Count, 1 To xlRange.Columns.Count)
           For indRow = 1 To xlRange.Rows.Count
             For indColumn = 1 To xlRange.Columns.Count
               arResults(indRow, indColumn) = xlRange(indRow, indColumn).Interior.Color
             Next
           Next
         GetCellColor = arResults
        Else
         GetCellColor = xlRange.Interior.Color
        End If
    End Function
    Function GetCellFontColor(xlRange As Range)
        Dim arResults()
        End If
               arResults(indRow, indColumn) = xlRange(indRow, indColumn).Font.Color
             Next
           Next
         GetCellFontColor = arResults
        Else
         GetCellFontColor = xlRange.Font.Color
        End If
    End Function
    Function CountCellsByColor(rData As Range, cellRefColor As Range) As Long
        Dim indRefColor As Long
        Dim cellCurrent As Range
        Dim cntRes As Long
        cntRes = 0
        indRefColor = cellRefColor.Cells(1, 1).Interior.Color
        For Each cellCurrent In rData
            If indRefColor = cellCurrent.Interior.Color Then
                cntRes = cntRes + 1
            End If
        Next cellCurrent
        CountCellsByColor = cntRes
    End Function
    Function SumCellsByColor(rData As Range, cellRefColor As Range)
        Dim sumRes
        sumRes = 0
                sumRes = WorksheetFunction.Sum(cellCurrent, sumRes)
            End If
        Next cellCurrent
        SumCellsByColor = sumRes
    End Function
    Function CountCellsByFontColor(rData As Range, cellRefColor As Range) As Long
        Dim cntRes As Long
        cntRes = 0
        indRefColor = cellRefColor.Cells(1, 1).Font.Color
            If indRefColor = cellCurrent.Font.Color Then
                cntRes = cntRes + 1
            End If
        Next cellCurrent
        CountCellsByFontColor = cntRes
    End Function
    Function SumCellsByFontColor(rData As Range, cellRefColor As Range)
        Dim sumRes
        sumRes = 0
            End If
        Next cellCurrent
        SumCellsByFontColor = sumRes
    End Function
    When I use the fomula: "=CountCellsByColor(R6:R3179,R14)" [Column R has three colors: Red non compliant, {r14} Yellow pending and Green compliant] and I use another column to filter by unit (there are 152), what I need is the countCellsByColor to return the COUNTIF for only the visible cells.
    On other cells I use:
    =SUMPRODUCT(SUBTOTAL(3,OFFSET(Z6:Z3179,ROW(Z6:Z3179)-MIN(ROW(Z6:Z3179)),,1)),ISNUMBER(SEARCH("NOT ASSIGNED",Z6:Z3179))+0)
    This works for text but I need somthing simular for colors. Either reference the Font Color or Cell Color as in the VB above.
    Can you help me, please?
    2016-05-06T10:13:22+00:00
    Sometimes simple is best - worked for me!
