COUNTIF on cell color
2010-11-01T12:09:13+00:00
Within Excel, I have a matrix of programs horizontally and accounts vertically and I have evaluated the performance of each intersection of the maxtrix with red (has concerning issues), yellow (has some issues), and green (no issues). At the bottom of my matrix, I'd like to use a COUNTIF formula to count the number of cells that are red, yellow, and green. What's the best way to COUNTIF on cell color? If needed, I can create a separate matrix that identifies the cell color by number (red,green,blue combination) and then do a lookup on that matrix.
Scott
2010-11-01T12:16:18+00:00
Excel has no native way of doing this so we must create a UDF to do it. ALT+F11 to open vb editor, right click 'ThisWorkbook' and insert module and paste the code below in. Close VB editor.
Back on the worksheet call with
=Countcolour($A$1:$J$1,K1)
Where:-
A1:J1 is the range you want to count
K1 is a cell with the fill colour you want to count.
Function Countcolour(rng As Range, colour As Range) As Long
Dim c as Range
Application.Volatile
For Each c In rng
    If c.Interior.ColorIndex = colour.Interior.ColorIndex Then
        Countcolour = Countcolour + 1
    End If
Next
End Function
If this post answers your question, please mark it as the Answer.
Mike H
2010-11-01T12:34:16+00:00
To expand on HansV (and MikeH's) comments... You might consider using the same criteria that you used to set the colors to count them.  If you used conditional formatting to color them, then use the same criteria to get a count of them using either SUMPRODUCT() [works for all versions of Excel], or COUNTIFS() [Excel 2007 & later only] to get a count.
Here are 3 example formulas assuming a list of integers in cells from A2:A7 that you want to count the cells in that are:
  1. greater than zero, but less than 11 (i.e. 1-10) (perhaps your RED cells)
  2. greater than 10, but less than 21 (i.e. 11-20) (perhaps your YELLOW cells)
  3. greater than 20, but less than 31 (i.e. 21-30) (perhaps your GREEN cells)
Using SUMPRODUCT():
=SUMPRODUCT(--(A2:A7>0),--(A2:A7<11))
=SUMPRODUCT(--(A2:A7>10),--(A2:A7<21))
=SUMPRODUCT(--(A2:A7>20),--(A2:A7<31))
Equivalent using SUMIFS()
=COUNTIFS(A2:A7,">0",A2:A7,"<11")
=COUNTIFS(A2:A7,">10",A2:A7,"<21")
=COUNTIFS(A2:A7,">20",A2:A7,"<31")
I am free because I know that I alone am morally responsible for everything I do. R.A. Heinlein
52 additional answers
  1. HansV 462.7K Reputation points MVP Volunteer Moderator
    2014-10-10T12:05:18+00:00
    Mike's code is a function to be used in a formula, not a macro that can be run.
    What was the name of the macro you tried to run, and what was the text of the error message?
    2014-12-09T15:06:47+00:00
    How can you get it to automatically recalculate the =Color formula if you add/change the colors of some cells without having to re-copy the formula down/across?
    Thanks!
    2015-07-10T18:19:56+00:00
    Hi Mike,
     I know this is old, but this is exactly what I need! thanks a bunch! however I do have one question, is there a way to make this work with conditional formating? I have a table filled with Zip codes, each starting number has a different colour, but it will only see these in your formula if I highlight it manually, is there anyway to make this work with highlights that are given through conditional formating? thanks again!
