A family of Microsoft word processing software products for creating web, email, and print documents.
In table properties, make sure the table wrapping is set to None.
Pam
Recently I've moved over to office 2010, having been an Office user for 10+ years. My issue is with Word 2010. I'm ok in Word, no expert but get by and can do what I need to. I've never had the below issues before and have used this function many times on Word 2007.
When I am using tables I have selected the 'repeat header rows' function. However it is not working. Anotherwords, my header rows are not repeating on subsequent pages.
Also, when using tables, I have de-selected (from table properties) 'allow rows to break across pages', so that my rows shouldnt be split across 2 pages. However, this also is not working.
There are 5 tables in the document, all the tables were 'split' at some point via the 'split tables' function. I created the table from copying and pasting lines from a powerpoint document, then converting that text in to one table, then creating columns to the left and right of it and have hand typed the column headings.
I have tried the following, to no avail:
Is this a problem with Word 2010?
Help would be appreciated.
Pam
Select Table tools, layout, properties, row de-select Allow Row to break across pages. You will need to highlight the entire table first.
Deselect allow table to break across pages. Select whole table
Reselect table row header. Select row.
Reselect allow table to break across pages. Select whole table.
That's all. Best Luck.
How I got around this was to create a new table in word 2010 that is working correctly.
Use Format painter to copy the format of the new table and apply it to the table that has the issues.
That resolved it for me
