A family of Microsoft word processing software products for creating web, email, and print documents.
In table properties, make sure the table wrapping is set to None.
Pam
Recently I've moved over to office 2010, having been an Office user for 10+ years. My issue is with Word 2010. I'm ok in Word, no expert but get by and can do what I need to. I've never had the below issues before and have used this function many times on Word 2007.
When I am using tables I have selected the 'repeat header rows' function. However it is not working. Anotherwords, my header rows are not repeating on subsequent pages.
Also, when using tables, I have de-selected (from table properties) 'allow rows to break across pages', so that my rows shouldnt be split across 2 pages. However, this also is not working.
There are 5 tables in the document, all the tables were 'split' at some point via the 'split tables' function. I created the table from copying and pasting lines from a powerpoint document, then converting that text in to one table, then creating columns to the left and right of it and have hand typed the column headings.
I have tried the following, to no avail:
Is this a problem with Word 2010?
Help would be appreciated.
Pam
If you do that, the table will consist of nothing but header rows and will not work at all.
