Mouse right click no longer working in excel
2010-03-19T21:59:21+00:00
In any spreadsheet now the right click no longer opens the menu.  I can't copy and paste, edit or anything else.  The mouse works in word and other applications, and in fact works in the header or menus of excel.  But if I got to a cell, it will not open upon right click.
2010-03-20T04:35:08+00:00
Try this:
From your worksheet, press Alt + F11.   careful, that's ALT + F11
Next press Ctrl+G
Type in (or copy here and paste)
Application.CommandBars("Cell").Reset
Then press the Enter key.
Press Alt+Q to return to the worksheet.
Click your right mouse button on any worksheet cell.   Does your right click menu appear now?
2010-03-20T00:26:26+00:00
I think the sheet may be password protected.
Check in sample new file, if it happens the same.
If it works in sample file, check for below link for more troubleshooting steps:
http://support.microsoft.com/kb/919196
84 additional answers
    2018-07-30T06:48:09+00:00
    Thanks the problem was resolved
    2018-09-28T12:00:50+00:00
    Try this:
    Next press Ctrl+G
    Tom Urtis, Thank you. Am used to right click function since a long time and this puzzle was bothering me for some time since i use another system in another office i work in.I would be forced to use the key board or the tool bar functions roundabout. Thanks to you, now the function works. gracie. VishG
    2018-10-03T01:33:09+00:00
    I've attempted to correct the issue using a few of these suggestions.  These were worthless in fixing this!  Thanks for wasting my time.....
