Mouse right click no longer working in excel
2010-03-19T21:59:21+00:00
In any spreadsheet now the right click no longer opens the menu.  I can't copy and paste, edit or anything else.  The mouse works in word and other applications, and in fact works in the header or menus of excel.  But if I got to a cell, it will not open upon right click.
2010-03-20T04:35:08+00:00
Try this:
From your worksheet, press Alt + F11.   careful, that's ALT + F11
Next press Ctrl+G
Type in (or copy here and paste)
Application.CommandBars("Cell").Reset
Then press the Enter key.
Press Alt+Q to return to the worksheet.
Click your right mouse button on any worksheet cell.   Does your right click menu appear now?
2010-03-20T00:26:26+00:00
I think the sheet may be password protected.
Check in sample new file, if it happens the same.
If it works in sample file, check for below link for more troubleshooting steps:
http://support.microsoft.com/kb/919196
84 additional answers
    2016-01-17T17:25:40+00:00
    Tom,
    Your brilliant.  Thank you!
    2016-02-09T10:13:54+00:00
    On pressing right click my insert option is disabled i am not able to insert colunm using mouse
    2016-04-16T21:50:56+00:00
    Did not work -
