Mouse right click no longer working in excel
2010-03-19T21:59:21+00:00
In any spreadsheet now the right click no longer opens the menu.  I can't copy and paste, edit or anything else.  The mouse works in word and other applications, and in fact works in the header or menus of excel.  But if I got to a cell, it will not open upon right click.
2010-03-20T04:35:08+00:00
Try this:
From your worksheet, press Alt + F11.   careful, that's ALT + F11
Next press Ctrl+G
Type in (or copy here and paste)
Application.CommandBars("Cell").Reset
Then press the Enter key.
Press Alt+Q to return to the worksheet.
Click your right mouse button on any worksheet cell.   Does your right click menu appear now?
2010-03-20T00:26:26+00:00
I think the sheet may be password protected.
Check in sample new file, if it happens the same.
If it works in sample file, check for below link for more troubleshooting steps:
http://support.microsoft.com/kb/919196
84 additional answers
    2014-04-09T22:18:33+00:00
    It works for cells but I'm now having trouble with the tabs.  When I right mouse click on the tabs of each workbook I don't get a menu anymore.
    Is there a command for that?
    2014-06-05T15:12:20+00:00
    Exactly what I needed... Someone created a macro in a workbook I opened that was meant to limit format editing, but as a consequence, disabled many of my command bars. The sheet is now fixed by including: application.CommandBars("Cell").Reset and application.CommandBars("cell").Enabled = True in a macro that closes out the workbook. Thanks HerrrGG
    2014-07-08T16:56:33+00:00
    Go to options>>Add-Ins>Manage-(option-Excell Add-Ins)>Go
    Uncheck the checked items and click OK. It should work.
