Mouse right click no longer working in excel
2010-03-19T21:59:21+00:00
In any spreadsheet now the right click no longer opens the menu.  I can't copy and paste, edit or anything else.  The mouse works in word and other applications, and in fact works in the header or menus of excel.  But if I got to a cell, it will not open upon right click.
2010-03-20T04:35:08+00:00
Try this:
From your worksheet, press Alt + F11.   careful, that's ALT + F11
Next press Ctrl+G
Type in (or copy here and paste)
Application.CommandBars("Cell").Reset
Then press the Enter key.
Press Alt+Q to return to the worksheet.
Click your right mouse button on any worksheet cell.   Does your right click menu appear now?
2010-03-20T00:26:26+00:00
I think the sheet may be password protected.
Check in sample new file, if it happens the same.
If it works in sample file, check for below link for more troubleshooting steps:
http://support.microsoft.com/kb/919196
84 additional answers
    2014-02-12T10:00:49+00:00
    I have a few users experiencing this issue with Essbase installed.   Sounds like a common issue.  Wonder if Essbase will issue a fix?
    Jim,
    I found my particular problem: navigating to essbase > options > global, I discovered that I had somehow selected "enable secondary button" under Mouse Actions.  Deselecting this option solved it.  My right button on the mouse works correctly now.
    Ralph Carter
    @RalphCarter_56
    Don't know where you got the fix from but I read your solution and applied it on my users and it worked right away.
    Left them with a big smile on their face ! Didn't know a simple right click function restore would be a cause of happiness...don't need much huh!
    Anyway thanks a bunch!
    fgmichel
    2014-03-13T12:07:02+00:00
    Thanks a lot Jim!
    It worked for my user. Much appreciated!
    -Jose
    2014-03-26T18:21:14+00:00
    It works! Awesome!
    > Try this:
    > Open excel
    > hit alt-f11 to get to the VBE
    > hit ctrl-g to see the immediate window
    > Type this and hit enter:
    > application.CommandBars("Cell").Reset
    > Then replace with this line and hit enter:
    > application.CommandBars("cell").Enabled = True
    > Hit alt-f11 to get back to excel and test it out.
    Found at: http://www.excelforum.com/excel-general/357080-right-mouse-click-doesnt-work.html
