Mouse right click no longer working in excel
2010-03-19T21:59:21+00:00
In any spreadsheet now the right click no longer opens the menu.  I can't copy and paste, edit or anything else.  The mouse works in word and other applications, and in fact works in the header or menus of excel.  But if I got to a cell, it will not open upon right click.
2010-03-20T04:35:08+00:00
Try this:
From your worksheet, press Alt + F11.   careful, that's ALT + F11
Next press Ctrl+G
Type in (or copy here and paste)
Application.CommandBars("Cell").Reset
Then press the Enter key.
Press Alt+Q to return to the worksheet.
Click your right mouse button on any worksheet cell.   Does your right click menu appear now?
2010-03-20T00:26:26+00:00
I think the sheet may be password protected.
Check in sample new file, if it happens the same.
If it works in sample file, check for below link for more troubleshooting steps:
http://support.microsoft.com/kb/919196
84 additional answers
    2010-10-11T20:43:38+00:00
    I have the same issues ... Right mouse button is not doing anything, but works in other windows programs. Also selecting the Fileds list for a pivot table does not respond any longer ...
    Starting excel in Safe mode enables these features as expected, but restarting in normal mode results again in the same behaviour....
    Any good hint would be really appreciated !
    2010-07-21T17:19:31+00:00
    Do you have any new Addins such as Essbase that could be taking control of your right click functionallity.
    HTH... Jim Thomlinson
    2010-07-21T16:19:39+00:00
    I am having the same issue and it's sporadic.  It did it a couple of weeks ago and then at some point fixed itself.  It was fine yesterday and this morning it started again.  I restarted Excel numerous times and even rebooted my computer, to no avail. I tried your ALT + F11 but that did not fix my problem. When I hit the Enter key, it just moved it a line down from the command, it did not appear to show it did what it was supposed to to. Please advise.
