64 bit driver for DSN for MS access database
2010-01-21T16:03:27+00:00
I have windows 7 professional 64 version on my laptop.  I tried locating DSN (data source name) for MS access data.
It is giving me an option for only SQL server database.
Defining connectivity to MS access database through DSN is very critical to my ASP applications working through IIS (internet information services)  After reviewing the solutions on the web I concluded currently there is no 64 bit driver.
Should I downgrade my windows 7 professional to 32 version
Microsoft 365 and Office | Access | For home | Windows
2010-01-22T17:42:45+00:00
Hi smantha11,
Currently Microsoft does not have any 64 bit ODBC drivers available for the Office products.
However, as long as the application that you want to connect to is 32 bit, you can use the 32 bit ODBC drivers to create the DSN. To get to the 32 bit ODBC drivers, the 32 bit Data Source administrator must be used. The 32 bit Data Source administrator must be launched directly if you are using a 64 bit OS. The file should be located at the following path:
c:\windows\sysWOW64\odbcad32.exe
Hope this helps!
Kathy
ScottGem 68,840 Reputation points Volunteer Moderator
2010-01-22T22:50:50+00:00
You can download the drivers here:
http://www.microsoft.com/downloads/details.aspx?familyid=7554F536-8C28-4598-9B72-EF94E038C891&displaylang=e
This file will add Access to the list of file types in the ODBC administrator.
Not sure if its 32 or 64 bit. But it worked on a machine running 64bit Win 7
Hope this helps, Scott<> P.S. Please post a response to let us know whether our answer helped or not. Microsoft Access MVP 2009 Author: Microsoft Office Access 2007 VBA Technical Editor for: Special Edition Using Microsoft Access 2007 and Access 2007 Forms, Reports and Queries
50 additional answers
    2012-05-02T01:10:53+00:00
    thx.
    This worked like a charm!
    2012-07-08T15:13:57+00:00
    Few mounts ago I have found the answer. I don't remimber website name but I have found my old code and google it.
    That's what I have found: <PlatformTarget>x86</PlatformTarget>
    you need to write this code inside .sln file after "PropertyGroup" it realy saves all situation.
    Now you may connect to Excel 2007 or any other using OLEBC.
    You don't need admin rights to do it. Just install Microsoft ADE 32bit version and enjoy.
    More information you may found here: http://visualbasic.about.com/od/quicktips/qt/slnfiles.htm
    2012-08-11T08:46:50+00:00
