Error 3061 Too few Parameters. Expected 1
2011-09-10T21:05:32+00:00
I'm using a Union query as a Source for an Append query.  I will leave the code here.  tblGLTransactions and tblGLTranaactionNo. I don't know if that is causing a problem.  The tblGLTransactions has 2 fields, the fiest field GLTransactionNo is an autonumber field, so I didn't append to that field.  I need both tables because of the relationship for a form and subform for GLTransactions.  The entry I'm trying to append closes the year end.  Well, it should.
I should post the union query as well.   I have drained out John Vinson who has been helping my like crazy in the past two days.  This is the final step in completing this database and I cannoyt believe it crashes.
Here is the Union query ......I changed it.  No AccountTypeID and no AcctgDate.  IT's been modified for the extra fields. EDITED 09/12/11 12:51
SELECT qryYearEndReBalanceSheetTotals.AccountID, IIf([TotalTrans]<0,[TotalTrans]*-1,0) AS Debit, IIf([TotalTrans]>0,[TotalTrans],0) AS Credit, 0 AS GLTransactionNo, "Closing Entry" AS Source,qryYearEndReBalanceSheetTotals.TransDate FROM qryYearEndReBalanceSheetTotals
UNION ALL SELECT  ([Forms]![frmYrEndProcessing]![cboRetainedEarnings]) AS AccountID, IIf([SumOfProfit]<0,[SumOfProfit],0) AS Debit, IIf([SumOfProfit]>0,[SumOfProfit],0) AS Credit, 0 AS GLTransactionNo, "Closing Entry" AS Source, DLookUp("FiscalYearEndDate","tblMyCompanyInfo") AS TransDate FROM qryYearEndBalanceSheetProfit;
 Here is the code:  I created another query with GLTansactionNo and AcctgDate.   The same 2 fields as the table.  It still fails with the same Error 3061. Like the Title
   Thanks for any help.  this coded edited Sunday 09/12/11 12:54 pm
Private Sub cmdOkay_Click()
On Error GoTo ErrorHandler
    Dim dbs As DAO.Database
    Dim rst As DAO.Recordset
    Dim strSQL As String
    Dim lngID As Long
    Dim strMessage As String
    Dim IntMessageDialog As Integer
    Dim strTitle As String
    Dim intResult As Integer
     If Me!chkPrintFinancials = False Then
     MsgBox ("Print Financial Statements before Closing the Year End." & vbCrLf & _
     "Ensure Start and Fiscal Year End Dates are not Blank in My Company Information Form.")
     Else
                        If Nz(Me![cboRetainedEarnings].Value) = "" Then
                        MsgBox ("Choose an Account for Retained Earnings.")
                    End If
                End If
                    If Not Me.chkPrintFinancials = False And Me.cboRetainedEarnings > -1 Then
                   Me.cmdCancelAndExit.Enabled = False
                Else: Exit Sub
            End If
         DoCmd.Beep
                strMessage = "Are you sure you want to Close the Year End?"
                IntMessageDialog = vbQuestion + vbYesNo + vbDefaultButton1
                strTitle = "Confirm Year End Close"
                intResult = MsgBox(strMessage, IntMessageDialog, strTitle)
                        If intResult = vbNo Then
                                Exit Sub
                        End If
                        If intResult = vbYes Then
                            If IsNull(DLookup("FiscalYearEndDate", "tblMyCompanyInfo")) Then
                       MsgBox "Please fill in the fiscal year end date in the My Company info form", vbOKOnly
                        Exit Sub
                            Else
        strSQL = "INSERT INTO [tblGLTransactions] ( AcctgDate) SELECT AcctgDate FROM " _
        & "[qryYearEndGLTransactions] ;"
        CurrentDb.Execute strSQL, dbFailOnError
        lngID = DMax("GLTransactionNo", "tblGLTransactions")
        strSQL = "INSERT INTO [tblTransactions] (TransDate, AccountID, Debit, Credit," _
        & " Source, GLTransactionNo)" _
        & "SELECT TransDate, AccountID, Debit, Credit," _
        & "Source, " & lngID & " As GLTransactionNo FROM [qryuniYearEndFinalClosingEntry] ;"
        DBEngine(0)(0).Execute "qupdYearEndDateChanges", dbFailOnError
         MsgBox ("The Year End is Processed.")
    End If
End If
       DoCmd.Close acForm, Me.Name
        DoCmd.OpenForm "frmEnterGLTransactions"
        DoCmd.GoToRecord , , acLast
ErrorHandlerExit:
   Exit Sub
ErrorHandler:
   MsgBox "Error No: " & Err.Number & "; Description: " & Err.Description
  Debug.Print strSQL
   Resume ErrorHandlerExit
End Sub
Microsoft 365 and Office | Access | For home | Windows
2011-09-18T17:45:44+00:00
I will reply, Rob, if only to wish you good luck.  I wish I'd been able to resolve the issue for you, but I think we'd just be herding those kittens for evermore I'm afraid.
One final point of detail.  I'd recommend:
"#" & Format(Now(),"yyyy-mm-dd hh:nn:ss") & "#" & _
By using the ISO standard for date and time notation it caters for whatever Windows local date format is in use.  As you'd written it, it would fail on my system for instance as the UK short date format is dd/mm/yyyy, so 4th July would be changed to 7 April, which your neighbours to the south would not appreciate.
2011-09-12T23:19:56+00:00
Mea culpa. I left out spaces in two places.  BEFORE SELECT and BEFORE FROM
        & "Source, GLTransactionNo)" _
        & " SELECT TransDate, AccountID, Debit, Credit, Source," & lngID _
        & " FROM [qryuniYearEndFinalClosingEntry] ;"
If lngId is equal to 33, then Debug.Print should return
INSERT INTO [tblTransactions] (TransDate, AccountID, Debit, Credit,Source, GLTransactionNo) SELECT TransDate, AccountID, Debit, Credit, Source,33 FROM [qryuniYearEndFinalClosingEntry] ;
69 additional answers
    2011-09-29T15:55:35+00:00
    To avoid any circular reference, I changed the expression to [Debits] and [Credits].  I have to leave As Dabit and As Credit because those are the field names in the table.
    I still got error 3061.
    2011-09-29T21:19:01+00:00
    Hello John, and Hello Ken, if you read this.
    Forget about the last query.   I  GOT IT TOO WORK!!!!!!!!!!!!  I better be careful, but it looks like it is working.
    First of all John, Ken and I love you guys, Ken John Thanks alot for helping me complete the database.
    I broke down that UNION query into 2 steps.  It would not work because when I run the first sql,  the value of Sum of TotalTrans goes to zero.  I close out the accounts and the query cannot calculate the profit.  I tested it  and it posted the value of th combo, accountID 36, but with 0 as Debit and 0 as Credit.  So the profit was not posted.  I reran the query and it zero's out, so I assume profit cannot be calculted in tthe second query.  This the problem, I believe.
    So, I switched the queries and ran the profit query incode first, and then ran the closing of the Accounts second and it worked.
    My frustration of trying to create the perfect query would not allow this append to happen in 1 sql.
    I knew the first sql in the UNION query worked alone.  So I just kind of gave up and said append the profit in a seperate sql.
    HERE is the answer.  Someone cam mark this as answer please, because it is correct.   Thanks Ken Sheridan.  Thanks John Vinson Thanks Jogn Spencer and Gina.  Thank you.
    Here is the code: it's inverted, Ken.
    strSQL = "INSERT INTO [tblTransactions] " & _
         "(TransDate, AccountID, Debit, Credit, Source, GLTransactionNo, DateTimeStamp) " & _
         "SELECT " & _
         strTransDate & ", " & _
         [Forms]![frmYrEndProcessing]![cboRetainedEarnings] & ", " & _
         "IIf([SumOfProfit]>0,[SumOfProfit],0), " & _
         "IIf([SumOfProfit]<0,[SumOfProfit]*-1,0), " & _
         """Closing Entry"", " & _
          lngID & ", " & _
         "#" & Format(Now(), "yyyy-mm-dd hh:nn:ss") & "#" & _
         " FROM qryYearEndBalanceSheetProfit;"
         "SELECT " & _
         "AccountID, " & _
         "IIf([TotalTrans]<0,[TotalTrans]*-1,0) AS Debit, " & _
         "IIf([TotalTrans]>0,[TotalTrans],0) AS Credit, " & _
         "'Closing Entry' AS Source, " & _
         lngID & " AS GLTransactionNo, " & _
         "#" & Format(Now(), "yyyy-mm-dd hh:nn:ss") & "#" & " AS DateTimeStamp " & _
         "FROM qryYearEndReBalanceSheetTotals;"
    THANK YOU ALL SO MUCH!!!!!!
    LOVE ROB
    2011-09-29T21:40:08+00:00
    Well done!
