Error 3061 Too few Parameters. Expected 1
2011-09-10T21:05:32+00:00
I'm using a Union query as a Source for an Append query.  I will leave the code here.  tblGLTransactions and tblGLTranaactionNo. I don't know if that is causing a problem.  The tblGLTransactions has 2 fields, the fiest field GLTransactionNo is an autonumber field, so I didn't append to that field.  I need both tables because of the relationship for a form and subform for GLTransactions.  The entry I'm trying to append closes the year end.  Well, it should.
I should post the union query as well.   I have drained out John Vinson who has been helping my like crazy in the past two days.  This is the final step in completing this database and I cannoyt believe it crashes.
Here is the Union query ......I changed it.  No AccountTypeID and no AcctgDate.  IT's been modified for the extra fields. EDITED 09/12/11 12:51
SELECT qryYearEndReBalanceSheetTotals.AccountID, IIf([TotalTrans]<0,[TotalTrans]*-1,0) AS Debit, IIf([TotalTrans]>0,[TotalTrans],0) AS Credit, 0 AS GLTransactionNo, "Closing Entry" AS Source,qryYearEndReBalanceSheetTotals.TransDate FROM qryYearEndReBalanceSheetTotals
UNION ALL SELECT  ([Forms]![frmYrEndProcessing]![cboRetainedEarnings]) AS AccountID, IIf([SumOfProfit]<0,[SumOfProfit],0) AS Debit, IIf([SumOfProfit]>0,[SumOfProfit],0) AS Credit, 0 AS GLTransactionNo, "Closing Entry" AS Source, DLookUp("FiscalYearEndDate","tblMyCompanyInfo") AS TransDate FROM qryYearEndBalanceSheetProfit;
 Here is the code:  I created another query with GLTansactionNo and AcctgDate.   The same 2 fields as the table.  It still fails with the same Error 3061. Like the Title
   Thanks for any help.  this coded edited Sunday 09/12/11 12:54 pm
Private Sub cmdOkay_Click()
On Error GoTo ErrorHandler
    Dim dbs As DAO.Database
    Dim rst As DAO.Recordset
    Dim strSQL As String
    Dim lngID As Long
    Dim strMessage As String
    Dim IntMessageDialog As Integer
    Dim strTitle As String
    Dim intResult As Integer
     If Me!chkPrintFinancials = False Then
     MsgBox ("Print Financial Statements before Closing the Year End." & vbCrLf & _
     "Ensure Start and Fiscal Year End Dates are not Blank in My Company Information Form.")
     Else
                        If Nz(Me![cboRetainedEarnings].Value) = "" Then
                        MsgBox ("Choose an Account for Retained Earnings.")
                    End If
                End If
                    If Not Me.chkPrintFinancials = False And Me.cboRetainedEarnings > -1 Then
                   Me.cmdCancelAndExit.Enabled = False
                Else: Exit Sub
            End If
         DoCmd.Beep
                strMessage = "Are you sure you want to Close the Year End?"
                IntMessageDialog = vbQuestion + vbYesNo + vbDefaultButton1
                strTitle = "Confirm Year End Close"
                intResult = MsgBox(strMessage, IntMessageDialog, strTitle)
                        If intResult = vbNo Then
                                Exit Sub
                        End If
                        If intResult = vbYes Then
                            If IsNull(DLookup("FiscalYearEndDate", "tblMyCompanyInfo")) Then
                       MsgBox "Please fill in the fiscal year end date in the My Company info form", vbOKOnly
                        Exit Sub
                            Else
        strSQL = "INSERT INTO [tblGLTransactions] ( AcctgDate) SELECT AcctgDate FROM " _
        & "[qryYearEndGLTransactions] ;"
        CurrentDb.Execute strSQL, dbFailOnError
        lngID = DMax("GLTransactionNo", "tblGLTransactions")
        strSQL = "INSERT INTO [tblTransactions] (TransDate, AccountID, Debit, Credit," _
        & " Source, GLTransactionNo)" _
        & "SELECT TransDate, AccountID, Debit, Credit," _
        & "Source, " & lngID & " As GLTransactionNo FROM [qryuniYearEndFinalClosingEntry] ;"
        DBEngine(0)(0).Execute "qupdYearEndDateChanges", dbFailOnError
         MsgBox ("The Year End is Processed.")
    End If
End If
       DoCmd.Close acForm, Me.Name
        DoCmd.OpenForm "frmEnterGLTransactions"
        DoCmd.GoToRecord , , acLast
ErrorHandlerExit:
   Exit Sub
ErrorHandler:
   MsgBox "Error No: " & Err.Number & "; Description: " & Err.Description
  Debug.Print strSQL
   Resume ErrorHandlerExit
End Sub
Microsoft 365 and Office | Access | For home | Windows
2011-09-18T17:45:44+00:00
I will reply, Rob, if only to wish you good luck.  I wish I'd been able to resolve the issue for you, but I think we'd just be herding those kittens for evermore I'm afraid.
One final point of detail.  I'd recommend:
"#" & Format(Now(),"yyyy-mm-dd hh:nn:ss") & "#" & _
By using the ISO standard for date and time notation it caters for whatever Windows local date format is in use.  As you'd written it, it would fail on my system for instance as the UK short date format is dd/mm/yyyy, so 4th July would be changed to 7 April, which your neighbours to the south would not appreciate.
2011-09-12T23:19:56+00:00
Mea culpa. I left out spaces in two places.  BEFORE SELECT and BEFORE FROM
        & "Source, GLTransactionNo)" _
        & " SELECT TransDate, AccountID, Debit, Credit, Source," & lngID _
        & " FROM [qryuniYearEndFinalClosingEntry] ;"
If lngId is equal to 33, then Debug.Print should return
INSERT INTO [tblTransactions] (TransDate, AccountID, Debit, Credit,Source, GLTransactionNo) SELECT TransDate, AccountID, Debit, Credit, Source,33 FROM [qryuniYearEndFinalClosingEntry] ;
69 additional answers
    2011-09-18T00:11:20+00:00
    Error No. 3265 Item not found in this collection.
    I added this to the code.  I looked at your word mail merge app. and tried my best follow this eval function.
    Dim strQuery As String
     Dim qdf As DAO.QueryDef
     Dim prm As DAO.Parameter
    Added the above to my code on frmYrEndProcessing's    Okay_click event
        I copied part of the code and received the aboce error.  Is that  the error message  we're looking for?
                    Else
        Set dbs = CurrentDb
        Set qdf = dbs.QueryDefs(strQuery)
        For Each prm In qdf.parameters
        prm = Eval(prm.Name)
        Next prm
        Set rst = qdf.OpenRecordset
    strTransDate = "#" & Format(DLookup("FiscalYearEndDate", "tblMyCompanyInfo"), "mm-dd-yyyy") & "#"
    strSQL = "INSERT INTO [tblTransactions] " & _
        "(TransDate, AccountID, Debit, Credit, Source, GLTransactionNo) " & _
        "SELECT " & _
        strTransDate & ", " & _
        "AccountID, " & _
        "IIf([TotalTrans]<0,[TotalTrans]*-1,0) AS Debit, " & _
         "IIf([TotalTrans]>0,[TotalTrans],0) AS Credit, " & _
         "'Closing Entry' AS Source, " & _
         lngID & " AS GLTransactionNo " & _
         "FROM qryYearEndReBalanceSheetTotals " & _
         "UNION ALL " & _
         "SELECT  " & _
         [Forms]![frmYrEndProcessing]![cboRetainedEarnings] & ", " & _
         "IIf([SumOfProfit]>0,[SumOfProfit],0), " & _
         "IIf([SumOfProfit]<0,[SumOfProfit]*-1,0), " & _
         """Closing Entry"", " & _
         lngID & _
        " FROM qryYearEndBalanceSheetProfit;"
        End If
        End If
    ErrorHandlerExit:
       Exit Sub
    ErrorHandler:
      Debug.Print strSQL
    End Sub
    2011-09-18T00:25:10+00:00
    Good night ken
    Thank you.  My last post , not right.  I just realized you have it in a function.  I did not.
    2011-09-18T02:05:45+00:00
    Ken,
    I'm writing to you to let you know that I wanted to do a test. In an earlier post you refernced me to a link about lookup fields. I had asked about usung AccountID from tblChartOfAccounts in the design grid for qryYearEndReBalanceSheetTotals.
    I wanted to use, in a test, AccountID from tblTransactions(which is nested in the qryYearEndBalanceSheetTrans,
    I removed AccountID Field from TblChartOfAccounts and dragged in AccountID from the query. The results, like I mentioned were AccountNum, not AccountID, as a result of the Lookup Combobox that was created in the table tblTransactions.
    So, I deleted this lookup value in the table and made it a text box. Correct. The form has the lookup value and SELECT Statement to get it from tblChartOfAccounts.
    When I amde this change I got a parameter popup saying qryYearEndREBalanceSheetTotals.AccountNum
    So I though that was the cause. I later found another query where it caused this popup and delted the AccountNum value it was getting from the query,but as Expression 1. where are you? type of error in the Design grid.
    I git excitred, because when I ran the union query it was popping as a parameter, but after the deletion, the union query ran fine.
    So Itested the code when I opened form and Clicked okay with fieilds fiiled in and, I wanted that error to leave, but no it came up again as error 3131 Synatax error in FROM Clause, and all I can believe now is that it must be a syntax error.
    I cannot believe the **** (excuse me) that this has caused .
    Anyways, I thought I found it. I know when you suggested never to use a lookup field from a table. And I changed that.
    SO I got rid of AccountNum in the queries, it was there to help me identify an account Number rather than an AccountID, a little more meaningless.
    Im back at syntax I think.
    Rob
